Speaker Upgrade from JBL "Premium" System
Discussion in 'Prime Audio, Electronics, and Infotainment' started by 7707Prime, Mar 4, 2019.
  1. Gary Kahne
    Gary Kahne New Member
    V8K 2A5
    2022 Prius PHV
    Upgrade
    I hope you are reading this. When you said " Low bass is not enough and highs are not crisp enough?"
    It took my a few months to figure out why for the first time in my life I was turning off the music. Finally I turned the base almost all the way down and the sound went from "frankly disturbing" to only "simply deficient-in the low end". (I had put the bass all the way up to compensate for the absence of base.)
    Since I do not want to spend really big bucks I am wondering between 2 options: 1) add a powered under seat sub and leave the headunit bass set to about 20% or 2) take out all 6 speakers and replace them all with better speakers that can handle the bass without going all muddy as they now do, which is why I am turning off the music, regardless of source. Any comments on either of these choices would be greatly appreciated. Clearly and new amp , and all new speakers and a sub etc would be best, but that is just not going to happen . Thanks to you and any others who can chime in on this.
  2. Gokhan
    Gokhan Senior Member
    6,707
    2,658
    Paramount CA
    JBL in Gen 4 Prius Prime is a ten-speaker system. Dash and rear door speakers have two speakers put together, so eight total. The front-door speakers are single speakers, bringing it up to ten. As the OP said, the front-door speakers have a low-pass filter; so, they are subwoofers only.
  3. Gokhan
    6,707
    2,658
    Paramount CA
    I found that the JBL in Gen 4 Prius Prime sounds best at the default setting, meaning with everything set in the middle. It is actually pretty good, natural sound if you leave it there.
    I also owned a non-JBL Gen 4 Prius Prime before, and JBL is certainly better than the non-JBL audio.
    It is interesting that the JBL speakers have a lower power rating than the non-JBL ones but they produce the same or a higher sound level using the “GreenEdge” technology.
    #23 Gokhan, May 29, 2025
