Speaker Upgrade Questions
Discussion in 'Gen 3 Prius Audio and Electronics' started by Colonel Ronson, Aug 13, 2010.
  1. ajc
    ajc Member
    340
    38
    pa
    Go with a complete upgrade, here is my complete audio upgrade with pictures. Any questions let me know.
    --> http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/75574-complete-audio-upgrade.html
  2. Colonel Ronson
    Colonel Ronson New Member
    443
    33
    Tucson, AZ
  3. tandy22
    tandy22 New Member
    27
    San Francisco
    you can get a pair of Kenwood Excelons, Alpine type x, they come with a crossover. You could upgrade the speakers and leave the stock headunit, but in my opinion, i would say that the HU is more important if you want nice sound.
    For Clear sound, i recommend MB quartz
    I'm going to put in a doulble din headunit + navi on my prius sometime this week too! :)
  4. Colonel Ronson
    443
    33
    Tucson, AZ
    replacing the head unit is definately a priority over speakers. Installing high quality speakers on the stock HU= bad idea. The head unit can't spit out more than 6-7 watts so any high quality speakers will be seriously underpowered and will sound awful.
  5. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Nearly all coaxial and component speakers come with crossovers but rarely do they have crossovers to cut off low frequencies for the midrange. Thankfully, most modern head units do have a built-in crossover for this purpose.
    What you may be confusing with "clear sound" is likely just a boost in amplitude at higher frequencies and or the characteristic sound of different tweeter materials (MB Quart was famous for their tinny sound caused by titanium tweeters and it was a love or hate relationship). This doesn't neccessarily make for a cleaner sound. Because everyone hears a bit differently and has different tastes in what kind of sound they prefer, I think the best advice is to avoid generalizations between brands and go to an audio store armed with your favorite types of music and listen to a lot of speakers (sans any equalization) and hopefully with similar supporting equipment (head unit, amp, etc..). Figure out what is most pleasing to you and fits in your budget. The Prius interior is pretty forgiving when it comes to sound so the speaker in the sound room shouldn't sound too terribly different when placed in your car (when ambient noise is kept low). If it does sound different and you don't like it, an equalizer and/or playing with phase might help correct what you don't like. :)
  6. tandy22
    tandy22 New Member
    27
    San Francisco
    lately, i have installed a set of Dynaudio speakers to a customer's car, it was remarkable!!
    well, you should always listen to different speakers and make sure the speakers you buy suits you perfectly.
    also, after you have installed the speakers, listen to it for a while, play around with the headunit and find the sweet spot.
    hope you have a nice time doing it :)
  7. austingreen
    austingreen Senior Member
    13,714
    4,232
    Austin, TX, USA
    Just curious which dyn's and what amp did you put in?
  8. Colonel Ronson
    443
    33
    Tucson, AZ
    I installed my new Head Unit recently. Its really powerful. Volume is at 12 and its equal to volume 40 on the old stock HU. I probably won't be installing an amp after realizing how much power this new HU has. That considered, i probably wont dish out a lot of money for a speaker upgrade because the stock sounds improved already, although the sound is a little flat. I probably will just replace the speaker in the door and leave the factory squatters in place.
  9. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Did you try playing with the equalizer in the deck?
  10. Colonel Ronson
    443
    33
    Tucson, AZ
    Yeah i turned the EQ off, and its REALLY flat, but when i turn it on, you can still hear the flatness in the treble, and sometimes the bass is muddled. I've seen these stock speakers. They are nothing more than paper cones that weigh less than a magazine. I was going to install components, but without an amp, its pretty pointless.
  11. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I was thinking more along the lines of a custom EQ adjustment rather than the preset ones that HUs come with. :) With a 7-9band EQ or a 3 band quasi-parametric you can usually made the stock speakers sound ok or at least tolerable. :) Maybe somewhere down the road you can install one of the new tiny amps from JL Audio or ARC Audio and get those components you want. ;)
  12. Colonel Ronson
    443
    33
    Tucson, AZ
    yeah ive seen those really small amps, like the one AJC used. But those are upward $500. And since the volume on my HU is already so extremely loud at low volume settings, i dont imagine why i would ever need an amp unless i decided i want to ruin my hearing lol. ill replace just the woofers in the door with some mid-grade 2-way speakers and see how it sounds. If it sounds awful or weird, ill replace the squakers as well and just get components.
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Progressive upgrade is great.
    I added B-Quiet Ultimate first. It added more bass because the entire door became a woofer and the sound behind the speaker was isolated and did not cancel out the sound from the front.
    I then changed the speakers. There was more improvement and I wanted more. I upgraded the headunit and installed BASS600. This provided the most bang but a lot of bucks as well.
  14. Colonel Ronson
    443
    33
    Tucson, AZ
    Looks like im upgrading to components. My squakers are blown. i can hear crackling noises now everytime i listen to music.
  15. partsmore
    partsmore Junior Member
    85
    NE
    Does anyone have the specs and dimensions for the 2010 Speakers?
    Im upgrading to the best: Hybrid Audio and if I can get everything installed,
    and make a nice install - I'll provide a group purchase option.
  16. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    There are 2.6" squwakers in the dash, 6"x9" mid-bass' in the front doors. In the rear doors there are also 6.5" mid-bass' in the bottom and (if you've got the JBL upgrade)squwakers (also 2.6") in the top.
    I don't believe that Hybrid offers anything that would be a "drop-in" direct replacement....wiith the exception of the rear door mid-bass drivers.
    The L3 midranges might fit in the squwaker locations, but they are meant to be paired with a tweeter in order to play all the way up. The 6.5" round midbass drivers (L6) could be made to work in the front doors with some custom baffles....and they'd probably drop right in to the rear door's lower locations.
    The exact specs of the factory driver's are listed in an earlier thread.
  17. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    A 6x9" to 6.5" baffle for the front doors would be quite easy to make. There are also plastic baffles designed for this but I'm not 100% sure the mounting holes line up to the Prius door.
  18. austingreen
    13,714
    4,232
    Austin, TX, USA
    scooshe makes a plastic mount just for toyota 6x9 to 6.5 speakers. I used them on my install.
    Car toys and amazon have a low price on what is probably a discontinued focal speaker if you want to go high end
    http://www.amazon.com/dp/product/B001MSI9PW?tag=priuschatcom-20
  19. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Just my bonus adds... I have had stock, infinity ref, "MB Quarts" ~ just another impression (from an Android kb ~ so b easy).
    HU makes a big big dif ~ don't discount just doing that
    I mounted my Inf Ref(IR) and MB Q (MB) into the lower A pillar. Cosmetically the MB looks nice and very robust
    If I knew what I do now, I would simply.remove the squaker, and mount a tweeter in that spot (with xm and gps antenna below it). The squaker has around a 2" circle for sound. Mount your random tweeter there (hot glue sb your friend).
    The MB has a very large tweeter/mid side ~ which would fit nice. I think the MB is much better than IR.
    When doing the 6.5 side, the schosche is good only for ease. It is thin plastic. When I next open the doors, I will put in a custom cut mdf ~ with insulation (sound) all around everywhere.
    Worry about the front spkrs first
    Depending, I fit the IR crossover inside the squaker spot. MB is huge and won't fi there ~ but can b mounted in that area
    The MB/IR seems efficient ~ no need for external amp(s). Seems MB has a msrp at $550 but can b found for $130.
    I put dynamat all over, while I haven't finished, you *should* buy it or equiv whenever opening panels. Buy it by square foot on ebay.
    [IMGLINK][/IMGLINK]
  20. GeoGeek
    GeoGeek Member
    360
    31
    Auburndale, FL
    I've got those Focal 165 VR's in my work truck and love them...although I'm not sure how good the 6.5 & tweeter component setup would sound in the Prius if you put the tweet up in the dash where the squwaker is. That's a really good price on the Focals though.....I thought mine were a steal at $300 (delivered) when I bought them a while back.
