Speaker upgrade
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Nave, May 24, 2025.
  1. Nave
    Nave Junior Member
    Northeast PA
    I would like to upgrade the sound system. I have trim 5 with JBL but I think I blew them. Is it advisable to take off the door panels and solder in new/better speakers?
    Ty
  2. audiodave
    audiodave Active Member
    800
    272
    US
    You won't have to solder them in. What speakers are you thinking about? You can modify the tweeter pod to fit other tweeters within reason.
  3. Nave
    Nave Junior Member
    Northeast PA
    Thanks for the reply. I am looking at these for the replacement.
    I'm fairly new to this and am unsure about amps, and also if I need a coax connection or something else.
    Thanks again
    I
  4. PriusCamper
    PriusCamper Senior Member
    13,466
    5,432
    Pacific Northwest, USA
    Cheap or even expensive speakers won't sound much different unless you upgrade/add an amplifier under the seat.
  5. Nave
    Nave Junior Member
    Northeast PA
    I would do that with a little advise
  6. PriusCamper
    13,466
    5,432
    First step is, does your JBL system already have an amp under the seat and which speakers it powers. Can you post photo of current speakers and amp?
    As for shopping for an amp and a speaker, just find least expensive that have better numbers on the spec sheet than your current ones.
  7. Danno5060
    Danno5060 Active Member
    405
    209
    Wyoming
    You might want to upgrade the sound isolation/padding. That's the thing that's holding back the audio more than anything else. When they designed the Prius, they realized it's pretty quiet and didn't need all that much (unless driving near a Harley or diesel pickup) so they didn't put a lot of money and time into the sound padding. Also, there's a lot of the car's audio energy that's going out into the world, instead of being contained in the car. I can hear my wife's book on tape every time she pulls into the driveway. I tried listening to the car's audio system sitting in park in a quiet place. It wasn't as bad as I first thought.
    Unfortunately, upgrading the sound padding isn't that easy. There's at least one thread on that here - maybe not for your generation, but the process will be the same.
    For me, I gave up on having true high fidelity audio in the car. I get it if you're not at that point yet though.
  8. PriusCamper
    13,466
    5,432
    This is precisely what's wrong with all car audio... A vehicle is one of the worst places in the world to listen to a high quality sound system. People who spend big money on car audio are being scammed by a market that knows only sound engineers are going to realize they're selling garbage. Just upgrade with cheapest speakers and amps and you'll notice a big difference from OEM.
    Danno5060 likes this.
  9. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    If you hAve to solder the speakers in, you’ve got bigger issues removing them first.
  10. audiodave
    800
    272
    US
    Did you get those Morels?
