Specification differences between toyota aqua 2013 and 2014?
Discussion in 'Prius c Main Forum' started by zakky, Oct 7, 2014.
  1. zakky
    zakky Junior Member
    63
    colombo
    2014 Aqua
    Hi every one;
    Can any one explain me what is the interior and exterior Specification differences between toyota aqua 2013 and 2014 and which is best?
    thank you;
    zakky
  2. Matt H
    Matt H Active Member
    164
    104
    Okinawa Japan
    2012 Aqua
    Newer one gets better mileage. Newer one has re-calibrated suspension. Lots of people complained that the suspension was too stiff. Interior and exterior look the same, as far as I can see.
  3. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Would love to know how they accomplished a better ride and better mileage. I remember reading an interview with the head of design on the project back in late 2011 just before the Aqua was released in Japan stating that a more sophisticated suspension that would have given a better ride was sacrificed to save weight and keep the gas mileage up. "recalibrated" sounds like maybe they increased the shock travel slightly. There's only so much effect that can have, and the back end will still be the same. The car would require a major redesign to truly improve the ride, and it would have to increase the weight.
  4. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Japanese rating MPG? The Prius C didn't change in MPGs at all.
  5. Matt H
    164
    104
    Okinawa Japan
    2012 Aqua
    Yes. The older one was something like 35.4 km/l. Then the Honda Fit eclipsed it with a JC08 rating of 36, taking the hybrid fuel mileage crown. Toyota wasn't having any of that, so they did something to it, and the new Aqua is rated at 37 km/l.
    With the suspension, they changed the shock damping and spring rate. The older Aqua's feel like a race car. Bust your teeth out, hard. When I changed from the OE Dunlop's to Bridgestone Ecopia EP20's, the ride got much nicer, but fuel mileage seems to have suffered just a tiny bit. Time will tell.
