Speed limit signs
Discussion in 'Prime Main Forum (2017-2022)' started by Toptimus, Feb 8, 2017.
  1. Toptimus
    Toptimus New Member
    Bay Area, CA
    Does anybody know what the speed limit signs in the HUD are based on? I mean, is it based on static map data (which will sooner or later be outdated), or is it actually using the car's camera to detect and recognize signs?
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    I don't know the answer, but my understanding is that Tesla's similar function actually reads them from the camera. It wouldn't surprise me if both companies purchase/license speed-limit-sign reading software from a common vendor.
  3. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I don't think it's using the car's camera because sometimes when I'm on a 35 MPH speed limit street the HUD will say 25 MPH
    dalcon95 likes this.
  4. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    Map data.
    Lucifer, Mark57 and Mendel Leisk like this.
  5. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Static Map Data. Someone posted on my YouTube channel that it is displaying outdated info for his residence.
  6. Mendel Leisk
    42,264
    On our aftermarket Garmin Navigator the maps have speedlimit data, for most roads. And it can get out of date. There's some occasional anomalies too.
  7. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    It never works correctly
  8. priuscatprimeguy
    2,730
    2,640
  9. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    The Speed Limit is listed under the Heads Up Display. Must be in Advanced Prime only.
  10. priuscatprimeguy
    2,730
    2,640
    I have the Advanced model but it shows up both on the HUD and the MID if I remember right the MID should be displayed along with the compass
    #11 priuscatprimeguy, Feb 9, 2017
  11. 'LectroFuel
    880
    673
    I don't usually use the nav, but the sign shows up in the HUD and the MID.
  12. priuscatprimeguy
    2,730
    2,640
    I understand but Ukr2 was saying it shows up in the Advanced only and Ukr2 has a Premium
  13. Optimus PRIME
    180
    141
    SF Bay Area
    if you have the HUD enabled, the Speed Limit info as well as other Navigation info would show up on the HUD and not on the MID. If you disable HUD display, the Navigation info would show up on the MID.
  14. ukr2
    ukr2 Senior Member
    1,020
    278
    31
    Victor, NY
    OK, I found the Speed Limit on my Premium Prime.
    I've been keeping the Hybrid System Indicator in the MID.
    If you press the Right arrow on the right-side of the steering wheel, it displays the Compass AND the Speed Limit if the road has one.
    Strange place to have it.
    priuscatprimeguy likes this.
  15. priuscatprimeguy
    2,730
    2,640
    I didn't find your assumption to be true because the Speed limit info shows up on both the HUD and the MID simultaneously.:D
  16. bwilson4web
    16,512
    The speed limit sign looks like the optically based reader in our BMW i3-REx. Also, it appears to change at the same time as passing the sign. So let me propose a test.
    Put a piece of 'blue masking tape' over the optical reader and see if the speed limit signs still change.
  17. priuscatprimeguy
    2,730
    2,640
    Ok, you first:p
  18. jdenenberg
    jdenenberg EE Professor
    3,961
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Bob,
    I think that the displayed speed limit is driven by the GPS database, not optical recognition at least in my 2016 Prius.
    JeffD
  19. bwilson4web
    16,512
    Does your 2016 have TSS-P?
