Speed limit signs
Discussion in 'Prime Main Forum (2017-2022)' started by Toptimus, Feb 8, 2017.
  1. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Yes it does.
    JeffD
  2. bwilson4web
    16,495
    I've got to runs some errands today. I'll stop by Lowe's and get some blue masking tape to test.
  3. bwilson4web
    16,495
    Well I was wrong. It is map based:
    There was no speed limit indicator so I drove to a new development that has speed signs ... still no icon.
    So I got on a 50 mph cross town street and came to a construction zone and the speed sign icon did not change.
  4. Prodigyplace
    12,708
    11,847
    Central Virginia
    I believe in the UK and possibly Europe is is camera based, but they have standardized their speed limit signs. I suspect there are too many variants in the US to use the camera.
  5. bwilson4web
    16,495
    My BMW i3-REx handles them well in Huntsville AL.
  6. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    NOOOOOO!!!! really????????:D:p:LOL::ROFLMAO:
  7. Optimus PRIME
    Optimus PRIME Active Member
    180
    141
    SF Bay Area
    Yes, I tested this myself yesterday and found that to be true as well. Just didn't get to correct myself until now but you already have. LOL
    Thanks
    priuscatprimeguy and bwilson4web like this.
  8. PhilT
    PhilT Junior Member
    NorthEast
    Up until a few days ago, the speed limit sign showed up with the compass in the middle display, and appeared on the HUD for a few seconds with each new change in speed limit - then it would go off and the ECO meter would be redisplayed there. But now the speed limit signs appear NOWHERE, and I can't figure how to get that back. In the meter settings, it is set to display (I've tried all the options, although it has always been on the "With Caution" setting). I'm guessing I must have changed some setting but can't figure out what it might have been to lose those speed limit displays. Any ideas?
    (ETA: this is a 2017 Prius Four)
  9. Prodigyplace
    12,708
    11,847
    Central Virginia
    You posted in a Prime thread, not Gen 4. :(
    In the US, Gen 4 & Prime with navigation have the speed limits in the map database. In Europe, the car (attempts to ? ) read the speed limit signs. In the US, the Speed Limit display can be changed in the "Meter Customize menu on the MID.
    If "NorthEast" Means Scotland or some other country, you are on your own to find the answer.
  10. PhilT
    PhilT Junior Member
    NorthEast
    Sorry - I did a search on SPEED LIMIT HUD and it dropped me into this thread- I didn't notice it was for Prime. (Northeast in my case means New England, by the way). And I found the answer. In the Navigation app there is a speed limit listed under OPTIONS, and that for some reason was off. I turned it on and the display is now back where it was, showing the limits as it had previously. Both HUD and the compass panel show the icons appropriately.
    Prodigyplace likes this.
  11. Prodigyplace
    12,708
    11,847
    Central Virginia
    Glad you got it figured out. I looked at the users manual and guessed since I do not have Nav or HUD. It is probably documented in the Entune manual.
  12. xray22
    xray22 Junior Member
    31
    Vanouver, WA
    Do you know what "speed with caution" means??
  13. Prodigyplace
    12,708
    11,847
    Central Virginia
    Is that anything like the software that told me its task was "partially successful"?
    Sounds contradictory to me.
    priuscatprimeguy likes this.
  14. My issue is that the speed limits (on my HUD) are not always consistently displayed, and just outside of town, one displays 40 mph when the actual sign is 45 mph. Any idea how to force a software update?
  15. Prodigyplace
    12,708
    11,847
    Central Virginia
    I believe in the US the displayed speed limits come from the navigation software database.
    Mark57 likes this.
  16. So, how do I force an update? Or at least request an updated speed limit? Because the dealer said that the car gets free satellite updates for 5 years.
  17. Prodigyplace
    12,708
    11,847
    Central Virginia
    I do not believe navigation updates are free.
    Mark57 likes this.
  18. Mark57
    2,945
    2,740
    OK
    This info is in the NAV database which is on an SDMicro card in your vehicle.
    It's the same database that Garmin uses but tends to be behind because there is only one version update per year by Toyota. You have to buy a new card @ ~$169. There's no guarantee the new card will have the item that wrong updated. It takes individuals like you and me to report the wrong info to get it updated to the original NAV database provider, not Toyota. Then it can take a year or more to make it in if it does or not.
    The dealer is dead wrong, it does not auto update. The new Entune 3.0 just released on the 2018 Camry has one or two trim levels that do update, but not ours.
    Correct! They run about $169.00
  19. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    Has anyone been able to turn the speed limit pop-ups off? I used the setting indicated here but they still pop up. What am I missing?
  20. Prodigyplace
    12,708
    11,847
    Central Virginia
    Sorry for the confusion. I answered a Gen 4 user in a Prime thread with a section of the Gen 4 manual. I guess you can fire me now. :(
    I assume you have the wide screen. I only found information about the speed limit display for navigation.
    I see no settings for a speed limit popup in the main manual customizations section either.
    I guess you should have got a Gen 4 Liftback. My Trim Two does not have that popup because it does not have navigation. Want to trade? :LOL:
