Speed Sensor Malfunction
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Riki, Feb 27, 2023.
  1. ChapmanF
    19,058
    The two things are connected by pipes, so a leak in either one makes the accumulator pressure drop, and the same pump has to run to make it back up no matter what. So there isn't anything about the pump running or the accumulator pressure dropping that tells you which unit has the leak.
    Sometimes a mechanics' stethoscope will help decide which one has the leak.
    The leak is probably at one of the valves in the system, and if you're a betting sort, there's about a dozen of those in the top thing, delicate electrical ones, compared to about two in the bottom thing, dead-simple mechanical ones.
  2. imran Arshad
    imran Arshad Junior Member
    New york
    Hi brother sorry for bothering,
    I have same issue with my car did you got your problem solved?
    Code c0210?
