Speedo Calibration & Trim Level
Discussion in 'Gen 5 Prius Technical Discussion' started by PHEVGuy, Feb 17, 2024.
  1. PHEVGuy
    PHEVGuy New Member
    Ohio, USA
    2024 Prius Prime
    XSE Premium
    Hey everyone,
    Does anyone definitively know if there is a different speedometer calibration for the SE vs the XSE/XSE Premium (or LE vs the XLE/Limited)?
    The difference in circumference between the two wheel/tire sizes is only 1.77% (or 1 mph off on the speedo at 60 mph). I wonder if that is small enough to fall within the allowed 'margin of error' and therefore not require different calibrations?
    If folks want to post their trim level and their actual speed vs GPS speed, I can try to do some data correlation to find out that way (but we will need a few samples to make that work.)
    Example: XSE - 60 mph on the speedo shows 62 mph on the GPS
  2. KMO
    KMO Senior Member
    2,030
    751
    Finland
    2023 Prius Prime
    Don't know the answer to this, but I have some auxiliary data - there are suspension differences. When you go through the parts databases, there are different part numbers for various suspension bits (sorry, I don't recall which) for the vehicles with 17" and 19" wheels.
    What that relates to, I don't know. I guess stiffness adjustment for the different profile tyres would make sense. So they are fine-tuning, rather than just popping different wheels on the same car. So maybe they fine-tune the speedo too.
    vvillovv likes this.
  3. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    Historically, Prius speedos exhibit the opposite behavior: 60 MPH on the speedo equates to 58 MPH on the GPS/radar. You really don't want your speedo under reporting your speed. The traffic officer is not going to believe it when you say your indicated speed was only X when he clocks you at Y > X.
  4. jeremnyc
    jeremnyc Junior Member
    95
    2023 Prius
    I experience the opposite. I'm about 2mph slower than the speedometer shows. My suspicion is they calibrated it to the larger wheels.
  5. Mendel Leisk
    42,354
    Highly doubt it.
    I’m sceptical: all car manufacturers are legally obligated to ensure the speedometer displays at least slightly high, with any stock wheel/tire combo.
    #5 Mendel Leisk, Feb 18, 2024
  6. PickyAudioGuy
    PickyAudioGuy Junior Member
    16
    Chicago
    Chrysler speedometers are usually dead-on the GPS (in at least my experience with a few recently). But yes, the Toyota speedometers I've checked have all been on the order of 2mph above the GPS (that's good user experience... "I don't get as many tickets in my Toyota").
  7. rjparker
    rjparker Tu Humilde Sirviente
    11,116
    6,975
    Texas Hill Country
    My Toyota speedometer reads high. BUT Toyota does have and use different speed calibrations for each factory tire size.
    Now for the interesting part - the car’s ecus have very accurate speed - which you can access through the obd2 port.
    Bottom line is Toyota wants you to stay under the speed limit and overstates the speed on the instrument panel. In my case by 3-4%.
    As a result I monitor and alarm on the true speed and engine temp separately.
    It is one reason why some people are annoyed by Prius drivers on the freeway. We may think we are doing the 65 mph speed limit but are actually driving closer to 62.
    #7 rjparker, Feb 18, 2024
  8. vvillovv
    vvillovv Senior Member
    4,337
    1,519
    NY
    Much like everything else with Prius and monitoring aspects of our cars, it makes a difference what kind of GPS is being used for calibration. Is it a Garmin GPS device or an ODB11 app GPS reading or something else used.
    Beyond that is speed linear across the range of mph typically driven or even the entire speedo range.
    Seeing many calculations of almost all events posted by us here at priuschat are, static / one reading, observations, when many times these are things that are not always linear across the full range of data points.
    I like the idea of comparing GPS speed readings to Speedometer observations.
    Personally, I don't know if I'd trust my ODB11 app GPS readings as much as I'd assume one of the Garmin devices calculations.
    I think at least a few readings within the typical mph range of each member participating would be better than only one.
    I've noticed that extremely slow mph are not linear, but that is so far off normal everyday driving, that I never documented it, and it's not that far off to be noticeable easily, anyway.
  9. Mendel Leisk
    42,354
    On a single model of car?
    When there’s more than one wheel/tire combo from the factory, AFAIK they keep the tire OD’s close.
  10. mlbex100
    mlbex100 Junior Member
    49
    22
    South Bay
    Three Touring
    That might explain why the car always displays gas mileage figures that are about 2% better than what I observe at the pump. For example if it says I got 50mpg for 300 miles, it might take 6.2 gallons to fill it up.All three of my cars did this (Gen2, Gen3, and Gen4).
  11. Mendel Leisk
    42,354
    I don’t think so. Speedometer error is by legislation, and the car knows the more accurate speed behind the scenes. MPG error I’d speculate is intentional, requested by Toyota executives, as “rosy” as they can get away with.
    on my 3rd Gen, the very consistent “error” is around 7%, on the optimistic side of course.
    #11 Mendel Leisk, Feb 18, 2024
  12. PHEVGuy
    PHEVGuy New Member
    Ohio, USA
    2024 Prius Prime
    XSE Premium
    That is really good information, so if they are willing to swap ACTUAL parts, flipping a couple bits in a program are nothing. This makes me lean towards saying they maybe DID do different calibrations.
    Fuelmiser, I suspect you are correct (I was just using those numbers as an example.) I think most of my cars (various brands over the years) have all leaned towards showing faster than what you are doing.
    Hey Mendel, where did you find that, I'm genuinely curious? My research turned up the following:
    "The speedometer must be accurate to within plus or minus 8 km/hr (5 mph) at a speed of 80 km/hr (50 mph)."
    I'm not able to post links yet, but that is from Cornell Law.
    law.cornell.edu/cfr/text/49/393.82
    ASE has some other recommendations (I believe they are +/-2% OR +4/-0% of the max speed indicated (and as I understand it, their wording means if your speedo display maxes at 200 mph, it can read +/-4 MPH (2%) or +8 MPH (4%). (Admittedly I'm having trouble finding reputable sources for this one.)
    #12 PHEVGuy, Feb 20, 2024
  13. KMO
    KMO Senior Member
    2,030
    751
    Finland
    2023 Prius Prime
    Yeah, I'm skeptical on that statement too. Not least on what you define as "stock wheel/tire combo". There are no wheel choices offered on US Priuses, as far as I know, so no opportunity to switch between 17" and 19". LE/SE have 17", XLE/XSE/Ltd/Premium have 19".
    So why would a car always sold with 19" wheels have any requirement for 17" wheels that are not an option for it? How can you apply a rule to something you don't offer?
    Maybe if the two trim levels were bundled into a single homologation / type approval, but they're not - they're distinctly different cars, with different official efficiency figures.
  14. daisy555
    daisy555 Senior Member
    1,729
    716
    CT
    Dealership told me that switching an XLE from 19” wheels to 17” wheels is not recommended. The LE and XLE do not have identical components. I guess I need to get more info. The extra Toyota tire warranty is only for initial 6 yrs. If I had free flowing money or lived in an area that had well maintained roads, I wouldn’t be so worried about this.
  15. HacksawMark
    HacksawMark Active Member
    449
    318
    Oregon
    2023 Prius Prime
    XSE
    When dealerships say things like that, it really means "I don't know anything about the subject". It's not the 19 to 17 that is the concern. It's the diameter and width of proposed setup to the old. Having a 17 inch setup that is the same diameter and width of the 19 inch setup will do absolutely nothing to the drive components.
  16. Mendel Leisk
    42,354
    Earlier gens did have some differences. Our 3rd gen came with 17" wheels, has different steering and suspension. I think though with the advent of 4th gen they're all have same steering/suspension.
  17. KMO
    KMO Senior Member
    2,030
    751
    Finland
    2023 Prius Prime
    As I said above, in the parts database I did see some suspension part number differences between the 17" and 19" trims. Can't say what they were or why though.
    I'm not worried about getting smaller wheels, but maybe going from 17" to 19" might not be ideal, if they're adjusting suspension for expected tyre thickness. Could be excessively harsh.
  18. Hammersmith
    Hammersmith Senior Member
    2,493
    2,547
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    It is true that the suspension components are different between the 17" and 19" setups. Namely the shocks/struts, stabilizer bars, and front stabilizer bar bushings. I'm going to guess that the differences are because of the combined weight differentials between the whole car and the wheel+tire combo. IOW, it might be less about the differences in wheels and more about the heavier curb weight of the higher trims.
    That being said, Toyota seriously overbuilds their suspension components and I wouldn't let that stop me from changing wheel/tire setups. But I would also accept that those changes might have a very slight negative impact on handling/comfort and/or long-term longevity of the suspension components. A person just needs to balance their priorities and not think they can get something for nothing.
    Trollbait and KMO like this.
  19. vvillovv
    4,337
    1,519
    NY
    @daisy555 here are the 2023 - 2025 Prius Prime wheel specs from the wheel-size.com database, so you don't have to take anyone elses word on it.
    • Generation: XW60 [2023 .. 2025]
    • Production: [2023 .. 2024]
    • Sales regions: USA+, Canada
    • Power: 220 hp | 164.1 kW | 223 PS
    • Engine: 2.0 L, M20A-FXS, I4 , Hybrid
    • Trim Levels: SE, XSE, XSE Premium
    • Center Bore / Hub Bore: 60 mm
    • Bolt Pattern (PCD): 5x114.3 (5x4.5)
    • Wheel Fasteners: Lug nuts
    • Thread Size: M12 x 1.5
    • Wheel Tightening Torque: 103 Nm
    Code:
    TIRE                 RIM           OFFSET   OFFSET range (mm)
    E195/60R17          6.5Jx17         ET40         38 - 42
    OE195/50R19         6.5Jx19         ET40         38 - 42
    tire size comparions tool at tiresize.com and get a 17" tire that is close to if not exactly the same diameter and width as the 195/50R19 tire
  20. daisy555
    1,729
    716
    CT
    Thanks so much! On my walk today I was obsessing about whether I should be switching to an LE instead of XLE but I really want the comfort features of the XLE. I don’t have anyone to potentially switch tires out for me so I would be relying on a tire store or dealership. Maybe not do anything unless I have an issue with the OEM size. I guess selling the 19” wheels would be easier if they were new but I don’t have a place to store them while trying to sell them.
    I really wish Toyota had just made all levels 17”. What a PIA.
    I did find this:
