Speedometer discrepancy
Discussion in 'Prime Technical Discussion' started by Njner, Aug 5, 2018.
  1. RRxing
    RRxing Senior Member
    2,559
    1,834
    NEPA
    Just to repeat my previous post:
    "Actually, it is because Manufacturer's don't want the liability if the speedo should read LESS than the actual speed, and you get a speeding ticket. It typically will read about 2-3 mph high."
    To add to that, I believe there is a "United Nations" agreement that specifies this discrepancy.
    Actual speed being 2MPH lower than the speedometer reading is what I'm seeing as well.
  2. fuzzy1
    10,652
    Yes, but nearly all the signatories to that particular UN standard (the one linked from PriusChat multiple times in the past decade) are EU and Asia-Pacific countries. None are in the North/Central/South Americas region.
  3. Mendel Leisk
    42,148
    How much hand-wringing can we do over this? If you're adamant to do the actual limit: "speed" by 2 mph, done?
  4. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    For me, it’s a question of accuracy.
    “Sir, do you know how fast you were traveling?”
    “I think so, Officer. You see, the speedometer said I was driving 67, which - according to the United Nations - actually means I was driving 65.”
    “Step out of the vehicle, sir.”
  5. Mendel Leisk
    42,148
    I guess not. :rolleyes: :ROFLMAO:
  6. Pierre Kay
    Pierre Kay Junior Member
    Lawrenceville, NJ
    On Toyos the speed was 1 mph low according to Waze and Garmin... temporarily on Hankook 737 and now the speedometer is 2 mph low... switching to Bridgestone next week...
  7. Njner
    Njner Junior Member
    2018 Prius Prime
    They’re my hands, I’ll wring them if I want to! ;) But thanks for taking the time to add nothing to the discussion. (y)
  8. Mendel Leisk
    42,148
  9. RRxing
    2,559
    1,834
    NEPA
    That's what I would say... :whistle:
  10. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Adding nothing to a NOTHING discussion........
    Seems about right to me.
  11. Brian in Chaparral
    Brian in Chaparral Junior Member
    Chaparral, NM
    2014 Prius v wagon
    I have driven a 2014 Prius V for the last three years. I installed a dash camera when I took ownership. On this dash camera it displays the gps-based speed of the vehicle. There has always been a discrepancy between the gps and the vehicle. The gps says 70 mph and the vehicle indicates 74 mph.
    However, about two weeks ago my dash camera gps and the vehicle indicate the same speed. Things that make you go hmmm.
    Has anyone else experienced this phenomenon?
    I know that the speedometer is electronic, as opposed to a gear-driven cable, And I am sure that tweaking a few lines of code can result in different speedo readings.
    My conspiracy theory me has believed that the 'faster' reading was just industry's way of reducing speeding on our nations roads. Is Toyota secretly contacting my car to update software?
  12. ChapmanF
    18,856
    I don't think the gen 3 or v had capability for that kind of secret update.
    It's an open secret around here that the combination meter display exaggerates. You don't even need to compare it to GPS-indicated speed: just use any OBD-II scan tool that can show you live data, and have it show you the actual vehicle-speed PID the brake ECU computes from the wheel-speed sensors. You'll see that it's accurate—and that's the exact number that the combination meter requests from the brake ECU over CAN—and then exaggerates for display.
    I'm kind of surprised you had that moment where the combo meter and GPS reading didn't look different. I doubt anything changed about the car. Maybe the GPS reading was less accurate than usual just then. Something about the terrain, maybe?
    fuzzy1, Mendel Leisk and PrimeDan like this.
  13. PHEVisthefuture
    PHEVisthefuture Junior Member
    76
    22
    Illinois
    My 2017 Prius Prime Base is exactly off by 1MPH on flat ground, confirmed by both GPS and speed radar signs. I've noticed other cars being much more inflated, by as much as 10%, on stock wheels and tires. Oddly enough, depending on elevation and terrain, sometimes my Prius is right on the mark (no discrepancy) and other times, it's reading over by 1.
    Good to know that if I ever got pulled over (I don't speed), I could say "officer, I was going exactly the speed limit" if I was over by 1 :)
  14. schja01
    schja01 Senior Member
    1,862
    1,234
    Chicagoland
    2024 Prius
    Limited AWD-e
    Every one of the half dozen Toyotas I’ve owned since about 2000 had speedometers that read 2mph higher than the actual speed. I’ve heard it’s intentional. For legal liability reasons. Only hearsay but sounds reasonable.
  15. PHEVisthefuture
    76
    22
    Illinois
    When I lived in Northern WI oftentimes I ran a tire that's 1 aspect ratio larger for ground clearance, and it actually FIXED the speedometer back to +/- 0mph. Messed with the gearing though, had to cruise in 5th & would easily stall out in 1st if you weren't careful (no "granny gear" like trucks have lol)
  16. fuzzy1
    10,652
    Speedometers reading higher than actual speed, has been a standard industry-wide practice for generations. Analog-era speedometers suffered significant measurement errors, so legal standards in some places forced them to bias the average display to read higher than true speed by enough that most of the meters erring on the low side of the bell curve were not reading lower than true speed.
    Today's digital measurements are much more accurate and consistent than the old analog era equipment, with effective tire circumference being the only significant 'analog' element remaining in the measurement chain. But the old industry practice continues.
