Speedometer display blank, car won't turn off
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Albert Harris, Oct 17, 2012.
  1. bisco
    52,855
    no, check the pertinent threads here. someone may have listed it. if no luck, you could call matt at texas hybrids, he might be willing to divulge his secrets.
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    use search forums tab up top and search
    combo meter
    Lots of combo info in there. need some low esr replacement caps. I'm on my second year of replacement combo form Texas Hybrids.
    Install:
  3. Tombukt2
    Tombukt2 Senior Member
    13,861
    2,519
    Durham NC
    I’ve got the mess torn apart . I need all the vents the ones that break I’ve you touch upper glove box door assy too. This in a taupe metal flake lookin old lady car . My speedo comes n goes . Car 12 is great 13.9 at charge . 12.8 sitting . Window switch is flashing driver side window works . Car drives better than my persona ..40 mpg now..trunk is ok . Shut off happens by smartly pressing button . MFD fully functional stereo and I pod too.Wth.
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
  5. Tombukt2
    13,861
    2,519
    Durham NC
    I’ve read all the threads whew . Funny tho my car cuts off . Trunk opens . 12V ok . I’ve codes but no chk engine light has sometimes.. scanner always inline. Speedo will go out . few stops it’s back on trip meters reset. Then today the vsc abs and one next to it all lit up . But nothings wrong car perfect.. 46 mpg . Drive it like stolen daily.. never issue 10 years
  6. Tombukt2
    13,861
    2,519
    Durham NC
    Getting another tomorrow 650
  7. PatrickEE
    PatrickEE Junior Member
    Michigan
    Four Touring
    Thank you! But I just read this too late (2023.12.18). Out of warranty now. Symptoms still happen from time to time.
  8. dolj
    dolj Senior Member
    8,646
    4,397
    Wellington, New Zealand
    Texas Hybrid Batteries can help if you can DIY the remove and replace. This is the best way forward for this problem now.
  9. Tombukt2
    13,861
    2,519
    Durham NC
    Just hold the button down it'll turn off when you open the door if you don't have the open door icon go back and adjust the ground till it comes on yep right there under the headlight on the right side and then go open the door see the icon you'll have a display when you start or ready the car Yes it may be time for the display to have the three capacitors dealt with.
