Speedometer display not working
Discussion in 'Gen 2 Prius Technical Discussion' started by Michael Warren, Nov 13, 2018.
  1. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    And I third him. ;)
    Skibob and Raytheeagle like this.
  2. Fakhar87
    Fakhar87 Junior Member
    28
    Pakistan
    Four Touring
    I have a speedometer console related question. During day time specially when driving towards the direction of sun i cannot see the speed i. E. Very hard to see and i havent found any brightness control option of speedometer. Its a 2007 model prius
  3. jerrymildred
    11,517
    14,164
    Tampa, FL
    Welcome. If yours is like the North American models it's #18 in the picture below.
  4. Fakhar87
    28
    Pakistan
    Four Touring
  5. jerrymildred
    11,517
    14,164
    Tampa, FL
    That's strange. I can well imagine it being in a different location, but I've never heard of a car without one. <scratches head> Does your car have a manual? If not, maybe you can download one from Toyota. The are on the Toyota website for our versions anyway. Don't know about other countries.
  6. dolj
    dolj Senior Member
    8,610
    4,370
    Wellington, New Zealand
    It is more likely a JDM, that is what they seem to have in Pakistan.
    @Fakhar87, do you drive with your lights on during the day?
    jerrymildred likes this.
  7. Fakhar87
    28
    Pakistan
    Four Touring
    No dear i dont drive with the lights on but when fog lights are on the display dims a little and when off it goes back to normal position
  8. dolj
    dolj Senior Member
    8,610
    4,370
    Headlights or fog lights (sidelights even) it makes no difference, the display dims as soon as you switch to the first lights on position.
    So, to adjust the panel brightness you use the button (to the right of the ODO TRIP button) at the bottom right of the MFD (multi-functional display).
    ODO-Trip:Display brightness Adjust.JPG
    It only does something when the lights are on. When you switch the lights on (first or second position) it will dim the CM (combination meter) and the MFD to the dimmed setting last used. Press the button with short quick presses and with each press it cycles through a Dimmed/More Dimmed/Most Dimmed cycle. Press and hold and the CM and MFD goes to full brightness. This would typically be used when having the lights on during the day.
    If you have a car that can change the speedometer between km/h and mph that button will have km/h and MPH on it, as illustrated below.
    This button works almost the same except press and hold will change the speedometer display alternately between km/h and MPH on each successive press and hold. Press the button with short quick presses and with each press it cycles through a Full Bright/Dimmed/More Dimmed/Most Dimmed cycle.
    Hope that helps.
  9. jerrymildred
    11,517
    14,164
    Tampa, FL
    That is a seriously cryptic symbol on that button. Good job!!
  10. dolj
    dolj Senior Member
    8,610
    4,370
    From what I can make out, it is supposed to be a speedo with a 5-pip progress bar across the bottom.
