Speedometer giving false reading
Discussion in 'Gen 2 Prius Technical Discussion' started by bramwell, Aug 17, 2007.
  1. mxvet
    mxvet humble
    26
    davenport, ia
    my 07, with 2,500miles is 1mph below the speedometer...at any speed, according to my trusty Garmin.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,081
    Northern Michigan
    <div class='quotetop'>QUOTE(madler @ Sep 14 2007, 01:00 PM) [snapback]512570[/snapback]</div>
    I find they do pretty well indicating vertical speed. My Garmin provides a good 10560 ft/min reference when dropped out the window, as long as you give it time to reach equilibrium. Other makes and models will provide varying reference speeds depending on their weight and drag characteristics. If used in a vacuum, they are only good for measuring vertical acceleration. :D
    Tom
  3. bwilson4web
    16,531
    When I replaced my tires, I took a short trip along a road with mile markers and cross checked the trip meter mileage with the markers. This allows me to figure out the error and deal with it.
    My current tires have less than a 2% error with ground truth miles.
  4. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    If I'm reading that regulation right, it doesn't say that the speedo has to register 10% high; it says that the speed must be at least the actual speed and no more than 10%+4km/h over. Because it can't read under, I can see Toyota biasing it a few percent over, but 10% seems excessive.
    As far as can tell, my US Prius reads very close the actual speed. I'll have to dig out my GPS and test it.
  5. ken1784
    ken1784 SuperMID designer
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(viking31 @ Sep 14 2007, 10:50 PM) [snapback]512463[/snapback]</div>
    I meant replace the speedometer with good one meeting the regulation.
    Toyota and all car manufacturers are just following the regulation.
    Ken@Japan
  6. Mike Stobbe
    Mike Stobbe New Member
    Reply to Paul B re speedometer error. I don't know how to fix a speedometer, but I wouldn't take your dealer's word that it can't be fixed. That's bullshit. Demand to speak to a Toyota technical manager. Remember, this is also effectively shortening your warranty, so keep your record of the dealer's measurement if you have one. You might also try calling a specialist speedometer repair shop. Good luck! Mike Stobbe.
    <div class='quotetop'>QUOTE(Paul B @ Aug 17 2007, 01:58 AM) [snapback]497691[/snapback]</div>
  7. patsparks
    10,664
    569
    Adelaide South Australia
    <div class='quotetop'>QUOTE(madler @ Sep 15 2007, 02:30 AM) [snapback]512570[/snapback]</div>
    What speed will it display then?
    If you know your speedo is out adjust for it, so what.
  8. madler
    madler Member
    289
    Pasadena, California
    <div class='quotetop'>QUOTE(patsparks @ Sep 15 2007, 03:26 AM) [snapback]512943[/snapback]</div>
    What speed will it display then?[/b][/quote]
  9. patsparks
    10,664
    569
    <div class='quotetop'>QUOTE(madler @ Sep 16 2007, 02:56 AM) [snapback]513050[/snapback]</div>
    Oh :eek: :lol:
    I checked my speedo against my GPS and had an error of about +1 to +2 km/h at around 60km/h. Pretty good really.
  10. silly
    silly Junior Member
    49
    Jacksonville, FL
    I've edited my post about a problem with my speedometer reading high. It ended up that I had accidentally hit the km/h button instead of having it set to mph.
  11. Sitting Duc
    Sitting Duc Feathered Member
    61
    Hamilton, New Zealand
    Interesting.
    I have the NZ(/AU, possibly JP derived) 2007 model, and have driven it about 300km; never touched the tyres.
    On the drive home from the dealer, I noted that over my standard 5km "trip meter check", the odometer registered 5.2km. Given no more digits, that represents 103-105% of reality.
    So for a "100km" journey on the MFD, I may have gone only 95km on the road.
    A day or so ago, the local city council put up their famous radar "your speed is:" billboards on a road I pass daily. Checking the digital speedometer against that displayed by the radar, I find the Prius to display as much as 3kmph more than the radar, at 40-50kmph. Meaning to do 50kmph, the glowing green numbers afore me have to read 53.
    So for a "100km" journey on the MFD, I may have gone only 94km on the road.
    For my last car (1997 Toyota Corolla, so also based on a Japanese design / model / variant),
    the odometer test was always less than 5.1km for 5km traveled, and the speedometer/radar was always spot on the money at 40, 50 and 60 kmph, even for an analogue dial. The city council refuses to put the billboards anywhere where I could get enough run-up for a 100 kmph test :)
    Maybe I should have stopped by the policemen with the nice laser speed trap I saw this morning and asked them to check my speedo(meter) after all.
    Given that both speedometer and odometer are misreading in the same direction, maybe by the same amount (3-7%); is it worth checking my (straight from the dealer) tyres to see if they agree to some sort of stated diameter? Or should I be content with starting a new topic about the great UN/Toyota conspiracy to upset non-US prius drivers? ;)
  12. ken1784
    2,943
    1,384
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Sitting Duc @ Oct 25 2007, 06:43 PM) [snapback]530138[/snapback]</div>
    My test result was different.
    The odometer was 0.2% error.
    The speedometer was plus 6km/h error.
    Ken@Japan
  13. ronhowell
    ronhowell Active Member
    681
    32
    Cypress, CA.
    Hi All,
    Just another input from the proud purchaser of a new 2008 model Prius. Rather than buy the optional Nav system at ~$2500 or so from Toyota. I purchased a Magellan Maestro 4040 GPS from Costco and installed it in the car.
    My readings of both while driving around Southern Cal have shown an amazingly accurate correlation between the two, with no discernable difference in reading. I am surprised at the quoted 10% differences being shown on European Prii. In this day and age that is a major dicrepancy, that owners or Toyota should not be complacent about.
    Ron
