Speedometer incorrect and Cruise Control Wrong
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Oct 9, 2017.
  1. Mendel Leisk
    42,387
    I think it's more than just whim too: there's legislation, UN accords on this?
    Belabouring a dead equine, but: I find it hard to get lathered up about this: if your speedometer says you're going 80, and you're actually going 78, this is a big problem?
    kithmo and RCO like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    OCD. :confused:
    fuzzy1, Mendel Leisk and kithmo like this.
  3. RRxing
    RRxing Senior Member
    2,564
    1,842
    NEPA
    Yes, there is. I looked it up a while ago but couldn't find it recently, but there is definitely at least one UN or international agreement related to speedometer accuracy - and it errs on the conservative side (e.g., if the car is actually in motion at 55 MPH the speedometer is going to read high, say...57 MPH.)
    RCO and Mendel Leisk like this.
  4. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I think He is dyslexic. ;)
    RCO likes this.
  5. fuzzy1
    10,724
    Note that the UN document linked here repeatedly in the past, is mostly an EU market standard with a fair number of Asian markets added in. None of the covered countries are in the (North, Central, South) Americas.
  6. bbald123
    bbald123 Thermodynamics Law Enforcement
    386
    275
    Harrisburg, PA
    I have finally found the US CFR that covers speedometers. As I expected, it doesn't solve the mystery of why all speedometers measure your speed as higher than actual. Speculation will have to rule the day.
    49 CFR 393.82 - Speedometer. | US Law | LII / Legal Information Institute
    "§ 393.82 Speedometer.
    Each bus, truck, and truck-tractor must be equipped with a speedometer indicating vehicle speed in miles per hour and/or kilometers per hour. The speedometer must be accurate to within plus or minus 8 km/hr (5 mph) at a speed of 80 km/hr (50 mph).
    [ 70 FR 48054, Aug. 15, 2005]"
    RCO likes this.
  7. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Plus or minus, that's interesting, depending how strict the speeding laws are, you could be breaking the law without knowing.
    pilotgrrl, RCO and Mendel Leisk like this.
  8. bbald123
    386
    275
    Harrisburg, PA
    And I suspect, though cannot prove, that is why car OEMs have the speedos set up to report a couple of mph faster than actual speed.
    RCO and kithmo like this.
  9. Mendel Leisk
    42,387
    The expression "each bus, truck, and truck-tractor" is puzzling. Also puzzling, the statement that speedometers can be inaccurate by up to 10%, in either direction. This runs contrary to every thing I've heard/read previously, and just seems irresponsible. Personally, I would much rather have a vehicle overestimate than underestimate speed.
  10. VTBIGDOG
    VTBIGDOG Active Member
    211
    146
    That's not what Click and Clack say:
    Blog Post | How much does tread wear affect the speedometer reading? | Car Talk
  11. Mendel Leisk
    42,387
    They go off the rails a bit, with this bit (highlighted in yellow:
    That typical new 25" diameter tire likely has tread depth around 10/32", and when down to the wear bars (legal mininum) has tread depth 2/32", which is an 8/32" difference, which is 1/4", not 1/2". Doing the math with that difference, their 4% becomes 2%:
    Also, how likely is the down-to-the-wear-bar scenario. Personally, 4/32's is the lowest I would go, more likely 5/32". And that measurement is likely taken at the inside tread edge, which tends to wear faster than outer edge, due to negative rear camber. Add all these factors, and the 2% dwindles to maybe 1%.
    fuzzy1 and RCO like this.
  12. Elektroingenieur
    2,515
    3,288
    Three Touring
    At the risk of prolonging an already-tedious thread, the section @bbald123 kindly cited comes from the Federal Motor Carrier Safety Regulations. See 49 CFR § 393.1, which explains that the rules in 49 CFR Part 393 apply only to commercial motor vehicles, as defined in 49 CFR § 390.5 by gross weight, number of passengers, or use to transport hazardous materials in quantity. Those regulations don’t apply to private passenger cars, for which there has been no Federal speedometer standard since the former FMVSS No. 127 was rescinded in 1982.
    There are still mandatory standards in Japan, however. Article 46 of the Safety Standards for Road Transport Vehicles (in Japanese) and its Attachment 88, Technical Standards for Speedometers (PDF in Japanese), requires that, at each required test speed:
    0 ≦ V₁ − V₂ ≦ V₂/10 + 4​
    where V₁ is the indicated speed and V₂ is the actual speed, both in km/h. English translations of these documents are available in the Automobile Type Approval Handbook for Japanese Certification, published by JASIC.
    I’ll let members in other countries comment on their own national standards, such as Regulation No. 39 (click the 39 tab on that page for links) promulgated by the United Nations Economic Commission for Europe under the 1958 Agreement, to which I note that neither the United States nor Canada is a signatory.
    bbald123 and RCO like this.
  13. fuzzy1
    10,724
    That column betrays nothing to indicate that they thought about this topic more than a minute, nor ever compared it to actual on-the-road results. Such as, shouldn't I be seeing a noticeable shift in my car's speedometer (compared to GPS) and odometer (compared to GPS and roadside mileposts and fixed routes repeated many years) readings as my tires wear down?
    And how does this fit in with the class action lawsuits about cars with odometers that read too high, shortchanging drivers on warranty coverage? If tire wear was a significant contributing factor, it should have been mentioned.
    Why did my attempts to match up engine RPM, manual transmission ratios, final driver ratio, car speed, and tire size, produce a quite noticeably incorrect answer when I used the basic circle equations from the tire size specs? Calculations came much closer to reality when I abandoned those circle equations, and instead used the tire RPM (revolutions per mile) spec.
    Based on my experience, and on past discussions about this with others here on PriusChat who have looked at similar things, I must dismiss this particular answer from Tom & Ray, until more formal detail is produced.
    That is because you live in a wetter climate, where tread depth is important. Many other folks live in drier climates down south -- it seems that California requires only 1/32" of tread -- and a significant chunk of drivers are cheapskates when it comes to tires. So there are a fair number of folks who actually do run down that low.
    #33 fuzzy1, Oct 15, 2017
    RCO likes this.
  14. Mendel Leisk
    42,387
    That, and with our low mileage, our tires are "aging out", before wearing out, lol.
    kithmo and fuzzy1 like this.
  15. bbald123
    386
    275
    Harrisburg, PA
    Excellent clarification! Thanks!
  16. Mendel Leisk
    42,387
    "0 ≦ V₁ − V₂ ≦ V₂/10 + 4"
    This bit says, in a very cryptic/obtuse way, that your actual speed should be less than or equal to the displayed speed.
    This bit, I think, is an even more cryptic/obtuse way of setting a limit on how high the speedometer can read, compared to actual speed? But my brain is full, lol.
    UltraJetRefill and RCO like this.
  17. Zardoz
    Zardoz Member
    86
    52
    Show Low, AZ
    I put over 50,000 miles on my OEM tires with no noticeable change in indicated vs actual speed with using my GPS as a standard. My car indicates between 1 and 2 mph faster than I am really driving.
    I just replaced the tires with the same and observed no change.
    UltraJetRefill likes this.
  18. Elt31987
    Elt31987 Active Member
    205
    155
    Derry, NH
    Yeah seems to be about 1.5 MPH faster than you are driving, and the Cruise control is typically 1MPH slower. So if you want to do 65MPH then set it for 68. lol confusing but something ive learned to live with
  19. UltraJetRefill
    156
    93
    Tucson, AZ
    My 1–2 mph offset is exactly the same as yours, even after 20 000 miles (32 000 km).
    #39 UltraJetRefill, Jan 7, 2021
  20. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    560
    Tucson, AZ
    2021 Prius
    I have an additional encouragement to remain at or lower than the posted speed limit. This vehicle has Road Sign Assist which reads and displays speed limit, yield, stop, and do-not-enter signs on the dashboard and in the HUD. If I set the cruise for 65 mph it will hold speed at 64 mph on the level and going downhill, and will usually accelerate that 1 mph to 65 when going uphill. The speed is displayed in whole mph but I think internally there is a tenths column. At 66 mph or more the little speed limit sign on dashboard and HUD will blink and a yellow border will appear around the sign. Sometimes it does this with the mph still reading 65, maybe internally 65.6. I can't confirm but I think at 10 mph over the posted speed limit the display will blink continuously and produce an audible beep.
