Speedometer/odometer reads high ‘18 Prime
Discussion in 'Newbie Forum' started by JLarson, Jan 17, 2019.
  1. JLarson
    JLarson New Member
    Delaware,Ohio
    2018 Prius Prime
    I’m finding my ‘18 Prime Advanved speedometer reads approximately 3.5% high...and therefore the odometer as well.
  2. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Yep that is the way it is for all most all vehicles sold in the US. Mostly in the 3% to 6% range but can be 10% for exotic cars. Add a couple more % as your tires wear out. The only law is a Federal rule that commercial truck speedometers be + or - 5mph. Much discussed here on Priuschat.
    49,402
    i wonder if a case could be made post warranty
  4. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    Let some air out of the tyres? :rolleyes: ;)
  5. Elektroingenieur
    2,515
    3,258
    Three Touring
    As @JamesBurke kindly points out, this is by design, as has been discussed here many times; see my replies from October 2017 and earlier this month, for example.
    The speedometer and odometer both take input from the wheel speed sensors, but as far as I know, only the speedometer display is made to read high. I wouldn’t assume the odometer is inaccurate unless you’ve checked it on a dynamometer or over a measured course, or the Data List feature of a Toyota Techstream diagnostic system were also to report higher-than-actual vehicle speeds.
