Spicer Rear Alignment Shims - Key Questions!
Discussion in 'Gen 3 Prius Technical Discussion' started by MrPete, Feb 7, 2024.
  1. MrPete
    MrPete Active Member
    507
    194
    Colorado, USA
    UPDATE: These are by MOOG not Spicer!]
    In another thread, @The Critic used NAPA-numbered versions of SpicerParts alignment shims, heavier duty than the typical SPC shims for fixing rear alignment.
    I'm needing to go down the same path, but running into roadblocks.
    I found the NAPA P/N's:
    * 2643055 "up to +/- 1/4 degree Camber & up to +/- 1/4 Degree Toe"
    * 2643056 up to 1/2 degree
    * 2643057 up to 3/4 degree...
    * 2643058 up to 1 degree
    BUT...
    1) I don't find anything like this at spicerparts.com -- do we have any idea who actually makes these?
    2) I find no instructions anywhere, and no calculator for needed settings to accomplish specific adjustments. Ideas?
    And finally, specific to my situation:
    * My rear toe is currently way out on the right but ok on the left. Am I correct in thinking I can adjust both a bit to obtain the needed total toe, and THAT is what actually matters for toe? (That's what I'm understanding as I read.)
    (In my case I need to do -.5 camber, +.5 toe on LR, and =.8 camber, +1.0 toe on RR.... so a 1/2 and a 1 degree shim for L and R....)
    OH: I see that NAPA gives these P/N's as alternates for the SPC shims. Might SPC instructions AND settings work for these very-different shims??? If so, I'm confused since SPC is just one part for all angles. These are different.
    #1 MrPete, Feb 7, 2024
  2. MrPete
    507
    194
    Colorado, USA
    Additional info: AFAIK, these shims are actually MOOG K6660-1 -2 -3 and -4 -- they are available from many sources (Home Depot !!! sells them for under US$7...)
    According to one comment at the Moog site, a chart comes with each shim showing the breakouts needed for any particular setting.
    SO, perhaps someone needs to take a photo of that chart? I'll search online to see if I can learn more...
    UPDATE: Rear wheel alignment, need help with the shims | PriusChat gives more insight... and a scan for part of the (?? -1??) version
    https://attachments.priuschat.com/attachment-files/2019/08/172021_alignment_help.pdf
    UGH. That scanned sheet adds confusion not clarity. Each box in the chart has a large number top-left that's the shim number to use. They go 1 to 6. But only 1 to 4 are sold?!!! And the discussion thread there shows that even the templates are way off...
    Anyone who has futzed with this and succeeded... insight would help!
    #2 MrPete, Feb 7, 2024
  3. MrPete
    507
    194
    Colorado, USA
    What a mess. PLEASE IGNORE THIS THREAD. I'm reposting with a more organized and accurate presentation.
