Spotting on Windshield from Lawn Sprinkler
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by inverness, Aug 11, 2009.
  1. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Bar Keepers Friend is a similar product. Both contain oxalic acid or something similar, and a very fine abrasive. The acid will dissolve water spots and rust stains, while the abrasive is fine enough to not scratch if used in moderation.
    Tom
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I'll second the Griot's fine glass polish. Several years ago, the first time I washed a brand new car I noticed there were what looked like water stains on the windshield, and to a lesser extent on the side windows, and nothing (glass cleaner, vinegar solution) would remove them. Got the Griot's cleaner, which worked great.
  3. prioki
    prioki Member
    116
    CA
    Thanks for the tip. I had the same problem when I had to park my Prius on the street. I just took it to my regular carwash, and it came off just fine. But how annoying! I just tried to avoid spots close to the sprinklers after that.
  4. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
  5. a64pilot
    a64pilot Active Member
    771
    62
    Albany Ga.
    While steel wool won't scratch glass if used intelligently, don't try scotch brite, Don't ask me how I know.:mad:
  6. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    I don't know if they have this product where you are, but it's called CLR Calcium/Lime/Rust remover and it's great for hard water spots. There's another product called Lime-Away that's not as good.
    In certain cases, hard water stains can actually etch glass. This happened to me in a prior vehicle. In that case, no amount of scrubbing will get them out. But, catch them early with some CLR and you'll likely be ok.
  7. janice45
    janice45 Dudley Girl
    82
    maine
    HI Folks
    Just a little note about the steel wool .I was at a Glass instalation & repair center saturday and I got to see first hand how the steel wool works .
    It is extremely fine and it does work and work well .Who would have ever thought.
    I'm amazed .Just thought I'd share:focus:
  8. nullxposur
    nullxposur Junior Member
    70
    San Antonio, TX
    Thank you! Now everyone won't think I'm trying to scratch their glasses on purpose! =)
  9. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    extremely fine anything works as a polisher. only difference between scratching and polishing is the size of the mark
  10. janice45
    82
    maine
    some people just need a little more direction and information sometimes thats all :D
