"Spotting" the GenIII: Differentiating the 2010 from the GenII
Discussion in 'Gen 3 Prius Main Forum' started by a priori, Aug 20, 2009.
  1. Tideland Prius
    16,547
    That's not a hole. It's a black rubber button as part of the Smart Key System. The Gen III hides the lock button underneath the rear plinth, next to the unlock button.
  2. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    That, and the sides are much deeper.. "more surface area" as when you rest your arm in the window, its now higher... gives the car a "pacecar look" to me.
  3. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Might work for the soapbox derby. :)
  4. krisirk
    krisirk Junior Member
    49
    24
    West Fargo, ND
    Noted. My post has been retracted.
    Kris
  5. Tideland Prius
    16,547
    did you want me to remove mine? cause I quoted you lol.
  6. windstrings
    6,280
    378
    Central Texas
    Took me a while to find it.. I had to actually look underneath to see it.. its a little tit just to the right of the open button.
    I used to better at finding those! ;)
  7. Tideland Prius
    16,547
    When I saw that at Detroit, I figured a few 2G owners might have a little problem with it, not because they can't find it but they might accidentally press it to unlock the car cause we're used to a full length release button.
  8. windstrings
    6,280
    378
    Central Texas
    The sad thing is I remembered someone pointing it out.. but I was so overwhelmed at the time with all the facts coming in.. I forgot.
  9. Tideland Prius
    16,547
    Well it was overwhelming for a lot of us. I don't know about you, but I forgot about the food! I only had a few bites.
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    the panel under the bottom rear glass goes all the way across the hatch, the Gen II was a littel ove a foot wide.
  11. windstrings
    6,280
    378
    Central Texas
    I like the batman wings on the rear tail lights!...... of course.. not good if you back into something!
  12. HelpSaveMotherEarth
    HelpSaveMotherEarth New Member
    70
    Bakersfield, California
    The rear above the licens plate there is a line that runs from sideto side on the Gen III. On the Gen II there isn't one there. Plus tires are different. Color choices. And much more
  13. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    It's the one that looks way hotter on the road (Gen3).
    I see them all the time on the freeway. The Gen3 looks much bolder and stout. The swept back roofline looks a lot more like a 'fastback' type of car.
    I think Toyota did a very good job, though not a huge fan of the full plastic wheel covers and the plastic inserts where fog lights would be on a Prius V.
  14. RMulligan
    RMulligan Junior Member
    Hawthorne, CA
    Four Touring
    The stubby antenna of the Gen III is easy to spot. From the side, I look for the "Nike Swoosh" of the tail light (I'm not a big fan of the Batman). I tried counting the number of reflectors on the tail light (two for Gen II and one for Gen III) but it is too hard to do when the car is moving. If approaching from the front, it has to be the fog lamp location (real or plastic). If approaching from behind, it is the Toyota logo and/or the antenna.
  15. bryonp
    bryonp New Member
    CA
    for me, it's the shape of the front headrests. the gen III are taller and more rectangle.
