Sprint (HTC) Touch & BT phone book transfer
Discussion in 'Gen 2 Prius Audio and Electronics' started by emtownsend, Apr 10, 2008.
  1. emtownsend
    emtownsend New Member
    111
    Post Falls, ID
    Hum... Seems that I cannot transfer ANY contacts to my Prius from my Sprint Touch phone. Not even one at a time. Anyone able to help?
    I have WM6.1 installed.
    Thanks!
  2. wayside
    wayside New Member
    30
    Old thread. Anyway, I was able to beam the contacts one at a time from the HTC Touch (on sprint) to the Prius but that really sucks. Has anyone moved the entire book in one shot?
    -Wayside
  3. silverbulletgrmi
    silverbulletgrmi New Member
    Grand Rapids, Michigan
    I'm having the same trouble now....the contacts don't seem to move from my Sprint Palm Centro phone to the Phonebook in the car. My dealer is checking into things and Toyota is supposedly sending a rep to look at it. Stay tuned.
  4. wayside
    wayside New Member
    30
    Hmm, I would think that we are having different problems. Since I can move one contact at a time I would have to put the blame on the phone for not letting me beam my entire phone book in one shot or me for not knowing how.
    If anyone should know if it is possible to beam your entire phone book via bluetooth (using the HTC Touch) please chime in.
    -Wayside
  5. Laikapup
    Laikapup New Member
    Depends on what version of windows mobile you're running. I have the HTC Touch Pro with Win Mobile 6.1. First setup your bluetooth and start the phone book transfer on your Prius (which you've done since you can transfer single contacts). On your phone, go into the full contact list. Touch "Menu", then "Select Contacts" then "All", and then do the "Send Contact" and "Beam".
    If it's an older Win Mobile (like 2003 or maybe 5), see if there's another way to select multiple contacts. If you have a virtual keyboard with "control" you can try control-A.
  6. ladscum
    ladscum New Member
    Wisconsin
    I have an HTC Touch Pro 2 running windows mobile 6.1 and when I select all contacts - or even any combination of multiple contacts the option to send via Bluetooth is greyed out and cannot be selected.
    Any other suggestions?
Loading...
