Sputter / rattling noise when engine on
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jep4040, Apr 1, 2024.
  1. jep4040
    jep4040 Junior Member
    17
    usa
    First, please bear with me, because I am a Prius newb.
    I have a 2005 Gen 2 Prius.
    Like the title states, whenever the car engine flips on, either the engine or muffler/exhaust(?) makes a sputtering or rattling type of noise. What could this be? Is this cause for concern?
    I Posted a video of the noise:
    Thank you!
  2. PriusCamper
    PriusCamper Senior Member
    13,428
    5,421
    Pacific Northwest, USA
    If it's just briefly on startup and not consistently, it's the nature of the Atkinson engine. But the video is hard to hear and you aren't providing additional information. How is the current MPG? Any warning lights on the dash? When was the last time you had a tune up? Oil change? Any other issues?
  3. jep4040
    17
    usa
    Idk just seems like the muffler is a bit loud? It's done this pretty much since I purchased it a couple of years ago... I haven't had any significant issues with the car itself overall, but this noise seems like it should be addressed?
    No warning lights
    Mpg ~38
    Oil change probably around 1k miles ago
    I purchased this car a couple years ago and that's when I got a very extensive tune-up...
  4. Tombukt2
    Tombukt2 Senior Member
    13,836
    2,514
    Durham NC
    Sounds to me like you've got some sputtering going on whether that is a miss if it is a miss. It's very consistent or it could be a loose gasket in the muffler system but that's a stretch need to get the car up on ramps and just have a look while the engine's running if you're afraid to do that a muffler shop will lift it up and have a look.
    jep4040 likes this.
  5. Tombukt2
    13,836
    2,514
    Durham NC
    The 38 miles per gallon is certainly a giveaway these cars get 40 on a bad day I realize 38 is just 2 mi away but for me to get 39 in any of my generation twos I have to connect my lightweight trailer and it's like the minute I connect the trailer the display changes to 39 mpg like clockwork it seems almost uncanny. Disconnect the trailer and it goes right up to 47.1 generally speaking. Me personally I'd have to be pulling the plugs out looking in my spark plug wheels checking the gaps If not just replacing the plugs I'm not sure about these expensive tune-ups there's really no such thing in this model plugs can be expensive if you want nice original factory guaranteed that sort of thing they can cost you 50-60 bucks in this day and age but other than that there's not much else to tune up I notice in most of these generation twos I work on the spark plugs are literally seated finger tight it's almost unnerving every one of these I work on I dropped my spark plugs extension socket in the hole onto the plug fit my ratchet with one hand and twist with one hand with almost no energy and I'm lefty loosening the plug right out One handed That's not good. Something is going on here and it needs to be checked probably on a lift Not necessarily at the exhaust shop but anybody who'll pick it up and have a look You've got a leak something is happening a constant miss when your foot's on the gas possibly The MAF sensor needs to be cleaned or it is badly built up something.
    jep4040 likes this.
  6. jep4040
    17
    usa
    Thank you, I really appreciate the insight. Like you said, I'll take it in and ask to put it up on a lift
  7. jep4040
    17
    usa
    Following back up on this -- i dont know why i thought i got 38 mpg. The correct MPG is around 45
  8. Tombukt2
    13,836
    2,514
    Durham NC
    Yes that is correct on it Very old car 2 miles less per gallon than what it shipped doing is pretty normal The car shipped rated at 47.1 by the EPA
    jep4040 likes this.
  9. Pinback
    Pinback Member
    62
    29
    Aboard The Prius Dark Star en route to Veil Nebula
    My 2009 (The Darkstar) was running rough at start up and clearly missing on #3 when cold. (according to the error logs I saw in tech stream: pending errors) I changed the coils, injectors, plugs and things greatly smoothed out. (180K miles I think) Also, you do change your ICE air filter when you change your oil right?
    If you think it is really coming from the exhaust, check the rubber mounts near the muffler, maybe they are worn out. You can probably see that visually or if the car is cool, grab the muffler/tailpipe and give it a shake. All the vibration should be "damped" with no hard stops. There are a couple of mounts at each end of the muffler and at the front of the resonator. As I recall all those have rubber in them which might be old and cracked and no longer soft. There is also a bracket towards the front that can get loose or damaged. Crack head thieves who try to steal your cat may damage that bracket if they are not experienced thieves. (I would use a Klingon word for them but this is a family venue.)
    Do you smell exhaust anywhere but at the tail pipe? (check just behind the passenger side front wheel for example)
    Beyond that I would echo Tmbukt's thoughts on running it on a lift and also checking the cleanliness of MAF sensor. Use cleaner solutions specific to the MAF sensor and follow their directions. And don't drop the sensor as they are fragile.
    Pinback
  10. jep4040
    17
    usa
    *UPDATE*
    Took it in to the mechanic. It for sure needed a new Muffler + Resonator pipe. Runs like a charm now--no sputtering/loud noise. Ended up costing $740 for parts and labor o_O
    Brian1954 likes this.
