SQ sound system in a 2020 Prius Base
Discussion in 'Gen 4 Prius Audio and Electronics' started by doitor, Aug 23, 2022.
  1. doitor
    doitor Junior Member
    28
    42
    Mexico
    2022 Prius
    After a long pause, its time to get back into the SQ game, so I decided to start a new build.
    The main goal is to build a stealth system in my daily driver.
    The car: 2022 Toyota Prius.
    Source: Ill use two. First, the OEM head unit connected via high level into the DSP. Second, iPhone/Ipod touch into a Topping D10 DAC via coaxial digital into the DSP.
    Speakers: Italia HiFi BL4 Carbon Fiber/Copper 3 way + 12 inch sub
    Amps: Two Italia HIFI D410 4 channel amplifiers. One for each side. Channel 1, 100 watts for the tweeter. Channel 2, 100 watts for the midrange. Channels 3 and 4 bridged to get 275 watts on the midbass. D135 Mono amplifier for the subwoofer (500 watts).
    Processor: MINIDSP C-DSP 8X12 DL
    Installer: Me.
    Picked the car up from the dealer on June 22, 2022.
    Removed the hub caps and got some wheel center caps.
    J.
    #1 doitor, Aug 23, 2022
  2. doitor
    28
    42
    Mexico
    2022 Prius
    What do you do the first day you get a new car?
    Take it apart, of course. LOL.
    The top of the dash comes out in under 10 minutes, 5 if you hold my beer.
    Tideland Prius and thomassster like this.
  3. doitor
    28
    42
    Mexico
    2022 Prius
    The doors also come apart pretty easy.
    Added a bit of deadener and put it back together.
    Moved onto the hatch area.
    Then the headliner.
    J.
  4. doitor
    28
    42
    Mexico
    2022 Prius
    lso did a bit of measuring.
    First, had to get the mic out and measure the OEM system.
    Then used the osciloscope to measure clipping on the front and rear speakers.
    With a 1 khz 0 dB tone, the fronts clip at 51/62 and the rears 53/62.
    With a 1 khz -5 dB tone, the fronts clip at 56/62 and the rears dont clip.
    With a 1 khz -10 dB tone, the fronts and rears dont clip.
    With a 50 hz 0 dB tone, the fronts clip at 54/62 and the rears 61/62.
    With a 50 hz -5 dB tone, the fronts and rears dont clip..
    With a 50 hz -10 dB tone, the fronts and rears dont clip.
    J.
  5. doitor
    28
    42
    Mexico
    2022 Prius
    The amps are here, just waiting on the speakers and this should move pretty fast.
    J.
    TGrracie and thomassster like this.
  6. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    This is awesome. I opened my car up the first year I bought it as well to install a new head unit, behind head unit amp, and new speakers and it was night and day. Thanks for sharing.
  7. doitor
    28
    42
    Mexico
    2022 Prius
    Speakers are here.
  8. doitor
    28
    42
    Mexico
    2022 Prius
    Sub is here:
  9. doitor
    28
    42
    Mexico
    2022 Prius
    Wires are here:
    Speaker Wire 3.jpg Speaker Wire 4.jpg Speaker Wire 5.jpg Speaker Wire 6.jpg Speaker Wire 1.jpg Speaker Wire 2.jpg
  10. doitor
    28
    42
    Mexico
    2022 Prius
    Also changed the interior bulb to led.
  11. doitor
    28
    42
    Mexico
    2022 Prius
    Weekend progress.
    First grabbed the OEM high level signal from the dash speaker harness.
    Heat shrink ready.
    Solder.
    Individual heatshrink.
    Heatshrink in pairs.
    Keeping the OEM theme with electrical tape.
    Label heatshrink.
    J.
  12. doitor
    28
    42
    Mexico
    2022 Prius
    Also started with the tweeters.
    Made some rings with acrylic and mdf.
    Aiming.
    Next step is shaping and boy filler.
    J.
  13. doitor
    28
    42
    Mexico
    2022 Prius
    Used some fiberglass bodyfiller, sanded then regular body filler and sanded some more. Had 80 and 240. Need to get 320 to finish.
    J.
  14. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    wow, appreciate the updates. I'm interested to know the final results.
  15. doitor
    28
    42
    Mexico
    2022 Prius
    Weekend progress.
    Sandig, sanding and more sanding.
    Running speaker wires.
    Terminating speaker wiring.
    thomassster and TGrracie like this.
  16. doitor
    28
    42
    Mexico
    2022 Prius
    Not a lot of progress this weekend.
    Installed the USB extension in the center console.
    The idea behind that is to keep the IPod in there. The right one goes into the Topping D10S, the left one is just 12v, so I hook up the Apple CCK3 into both and the Ipod into the CCK3.
    Also added the "I dont trust you with my system switch", which cuts the remote wire so the dsp and amps wont turn on.
    J.
  17. doitor
    28
    42
    Mexico
    2022 Prius
    First set of speakers are in. Woot, woot.
    The original speakers mounted from the top. Had an idea to mount them from the bottom and make a "waveguide". Made a ring with 1/8" mdf and held it in place with wood tongue suppressors.
    Used tape to make a mold.
    Fiberglass body filler.
    Regular boy filler.
    Covered them with black felt.
    Speaker mounted.
    Made the baffle from 1/4" acrylic, used speaker gasket tape on both sides of the baffle and duct seal on both sides.
    Added some deadener and hot glued everything that could rattle.
    Covered with speaker grill cloth and into the car.
    J.
    TGrracie likes this.
  18. Chris Wolfgram
    Chris Wolfgram Active Member
    424
    169
    Sacramento CA
    2019 Prius
    Your braver than I am
    My stereo guy said he could cut and splice wires, and guaranteed me he could make my DSP work "without" a factory harness ...
    But, he told me what I already knew, that if there were any electrical problems > even if < they were not caused by the stereo installation, Toyota would totally bring that up, and use it as an excuse "not" to honor my factory warranty ☹️
    If my car were out of warranty, I'd totally trust my install guy, but just can't risk losing my factory warranty.
    I sure would love to hear your system though ! As nice as mine sounded in my 2019, I'm sure this is nicer ! And that would say a lot !
    #18 Chris Wolfgram, Oct 9, 2022
  19. doitor
    28
    42
    Mexico
    2022 Prius
    If you ever come to Texas, shoot me a pm.
    J.
    Chris Wolfgram likes this.
  20. Chris Wolfgram
    424
    169
    Sacramento CA
    2019 Prius
    I actually plan to be traveling through there (South Texas) in May
