Square Oil Catch Can
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by NewHybridOwner, Jul 30, 2019.
  1. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Go with non vent, anything optional with a breather hole/screw avoid, even if put a screw in place of the breather vent hole, you gun have air leaks under high pressure. Speaking from experience :whistle:
    Jason Beauchamp likes this.
  2. CR94
    CR94 Senior Member
    2,830
    1,242
    Northwestern S.C.
    ?? High pressure? That shouldn't exist in the pcv plumbing. Did your engine backfire?
  3. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I’m in Maine, and it’s not a problem.
    The non-oil (water) liquid will freeze overnight, but will soon melt when the engine begins running.
    m.wynn likes this.
  4. NewHybridOwner
    NewHybridOwner Active Member
    607
    283
    W. Michigan
    I just bought this one. No vent at the top that needs to be sealed. I opened it up and found that there is no baffle between inlet and outlet, but probably I could add one, in addition to putting in some stainless-steel pot-scrubber material. I am also thinking of drilling and tapping the bottom to take a drain valve instead of relying on the easily-dropped drain plug.
    Ebay Item 362718363546
    #24 NewHybridOwner, Aug 14, 2019
  5. mjoo
    mjoo Senior Member
    1,163
    1,334
    Michigan
    No issue. In the extreme cold I do like @tvpierce and dump it after warming engine. Or I use a half gal of hot tap water to unfreeze.
    Pixel XL ?
    #25 mjoo, Aug 14, 2019
    Raytheeagle and Mendel Leisk like this.
