Squawker replacement for dummies
Discussion in 'Gen 3 Prius Audio and Electronics' started by psteudlein, Feb 10, 2014.
  1. psteudlein
    psteudlein New Member
    27
    Remember – I am non-technical. I have tried to read as much as possible about replacing the dash speakers/squawkers and got some of it, and on others get lost . I am just looking for the simplest/easiest route possible.
    I have already replaced the front and rear door speakers.
    Current car and speaker info:
    2013 Prius, non-JBL system, 6 speakers no sub
    Stock HU (do not want to replace)
    Front doors = Infinity 9632cf 6x9
    Rear doors = polk dxi651 6.5 round
    To be installed in dash = polk dxi350 3.5 round 90Hz-22kHz
    From what I have read, the dash speakers and front door speakers are wired in parallel. There is a stock bass blocker on the stock squawker, but full sound/range goes to the front doors…correct?
    I have gotten to and removed the stock dash speakers and have seen that the new dash speakers will fit with little cutting.
    Is this the easiest/simplest things to do:
    In order to keep and use the stock wiring and plug, just remove the stock bass blocker and attach it to the new speaker.
    Will this do the trick?
    Or should I use some other type of bass blocker…inline capacitor to “+” side.
    If this is done, I am not sure on how to wire it all, if the stock plug is removed.
    If I do have to buy an in-line bass blocker, what/which one would be best for the new speakers?
    Crutchfield has:
    (150 Hz cut-off)
    (300 Hz cut-off)
    (600 Hz cut-off)
    (800 Hz cut-off)
    …or other…
    Plan for the future, towards end of year, is to have an installer put in an amp and sub.
    Thanks for any and all help…Paul.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    see my signature for diy docs.
  3. psteudlein
    27
    I did read your document for the dash speakers but my new dash speakers do not have a built in crossover, like you mentioned yours did.
    So I still have my original questions regarding the stock bass blocker or some new bass blocker.
    What might be easier or better suited for my situation?
    Can I just do what you did, but put some new bass blocker from crutchfield between the stock plug and the new speakers?
  4. lopgok
    lopgok Member
    177
    30
    unknown
    I put in a 200 microfarad non polarized electrolytic capacitor. My concern was that this would provide a lower impedance load to the head unit, and I fear the head unit may not like low impedance loads.
    So what I did was install a 2 ohm resistor in series with both the squaker and the door speaker. This way the lowest impedance load the head unit will see is about 3 ohms. Since I now have a JBL-ms8, I will be removing the capacitor as well as the resistors.
    It is nice getting a wider frequency range from the squaker, but I have no idea what would happen if I didn't have the resistors in place. Given the head unit is quite expensive, I decided it was cheap insurance.
  5. psteudlein
    27
    lopgok,
    I believe my factory HU and stock speakers were all 4 ohms, and the new speakers are all 4 ohms...Is this something I should be worried about? I have the non-JBL version with 6 speakers.
    Does anyone know what kind/level/range the stock bass blocker is?
    If I was to go with a xxx microfarad non polarized electrolytic capacitor, which one would be appropriate for my new dash speakers (polk dxi350 90Hz-22kHz)?
    100, 150, 200, ...
    For the other front and rear speakers, I assume I just want the full range going to them.
    My concern now is if the stock bass blocker is ok or should I get a xxx microfarad non polarized electrolytic capacitor.
    Thanks all for the help.
  6. JGI
    JGI Member
    77
    46
    The dxi350 is a coaxial 2-way driver. Usually, a coaxial driver will have its tweeter "internally" high passed already. As for the woofer part, the 150Hz hi-pass from Crutchfield will do.
    The stock squawker has a cap soldered in, and you can definitely use that. Desolder it from the stock squawker and wire it in series with the coax. I have no idea what frequency it filters and personally I wouldn't use it.
    FYI, the Prius speaker wiring goes like this: HU -> Dash Tweeter -> Door Woofer
    There is a set of wires from the HU that connect TO the tweets and THEN to the door speakers.
  7. psteudlein
    27
    JGI...thanks for the info.
    After doing more research and reading more to understand, I read that the stock bass blocker on the stock squawkers is 6.8uf (or around 6000hz).
    I have decide to get some bass blockers from Crutchfield, but they recommend based off of speaker size, to get for 3.5 size speaker:
    (for low power system) 600hz
    (for high power system) 800hz
    I did read my new speakers Polk dxi350, come with a 200hz bass blocker, but I don't remember seeing them in the box, but will recheck.
