Squeaking sound from wheels during rolling start/Brake Noise (merged)
Discussion in 'Gen 3 Prius Main Forum' started by nemrut, Sep 6, 2009.
  1. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I managed to "fix" this on my own today.
    Solution? Panic stop!
    Caught a yellow light I felt would be better to stop at vs. blow through. The stop was hard enough to activate ABS and the smell of burning rubber. However.... since that stop, no more sqeaking upon roll-off or slow creep.
    Cause? Probably some rust or glaze that typical stops just won't rub off. Mine only started after a dealer car wash, so that would make sense.
  2. scottwyden
    scottwyden new jersey photographer
    342
    New Jersey
    I tried that on purpose but it still squeeks
  3. HTMLSpinnr
    5,339
    917
    251
    Funny thing is in a controlled situation (i.e. neutral braking), no dice. This was a stop from about 50mph.
  4. scottwyden
    342
    New Jersey
    Oh I understand.. but I did stop from going really fast too
  5. scottwyden
    342
    New Jersey
    Rick, did it come back or is it gone for good?
  6. HTMLSpinnr
    5,339
    917
    251
    It came back a day or so later. So much for that one....
  7. scottwyden
    342
    New Jersey
    Toyota should really figure it out at least for our ear's sake
  8. dc202
    dc202 Member
    230
    22
    Pacific Northwest
    IMHO, owners should get over it. It is NO BIG DEAL!!!:):D
  9. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    FWIW, since Seattle has had rain, my squeak has disappeared.
    You'd think the rust would be having a field day !
  10. Taebopro18
    Taebopro18 Prius Curious :-)
    24
    Cherry Hill, NJ
    Ok, so I read ALL 13 pages of this post so far, and I'm surprised no one has mentioned the problem I'm having. I do hear the squeeking, but only when i REVERSE! It happens when i first turn on my car after it's been sitting a while, and reverse out of my parking spot. Once I put the car into drive, no more squeeking. Has anyone else had this problem?
  11. scottwyden
    342
    New Jersey
    I dropped my Prius off for its first servicing.. I mentioned my rattles and the squeaking.. I'll report what they come up with.
  12. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    I hear it as well only in the early morning with cold brakes, it has nothing to do with overall external temperature. I had it on my previous car as well. No noise after braking once. I don't even notice it anymore and in any case the engine noise covers it during warm up phase after a few seconds I am driving. Never heard it with a warm car, that is, with warm brakes.
    I think it is due to the last final brake one gives at the end of the drive, before setting it into park/turn off.
  13. scottwyden
    342
    New Jersey
    My Prius was in for its first service this weekend. They said they couldn't hear the squeak (BS!) and everything looked good for each brake.
    I think it's a lost cause
  14. darenko
    darenko New Member
    Seattle
    Just picked up my Prius V from its first 5000 service and mentioned the squeek coming from my right rear wheel (for the last 3000 miles) and how the car has to be turned off for a few minutes to keep reproducing it. Sure cold weather and rain makes it happen more frequently.
    To my surprise, they were able to reproduce it and in fact when I questioned about it, the tech acknowledged that a few other customers have reported the issue and that Toyota has told them to re-lubricate the brake system as the tech noted that the side I was having issues with was not properly lubricated. What you ask they lubricated? I don't have the report in front of me, but he told me they disassembled the break system, lubricated and out of all the cars reported with this issue, none have come back.
    I will see if the fix actually worked when I pull out from work tonight as the car always exhibits the behavior when I leave and you can hear it in the parking garage for sure.
    He said unless Toyota tells them otherwise, they won't do anything else for the scenario but re-lubricate.
  15. hotbrass
    hotbrass New Member
    312
    34
    Cowtown
    It would be interesting to know what they lubricated.
  16. darenko
    darenko New Member
    Seattle
    So as not to leave you hanging, here are the notes from the invoice when I got my wheel squeeking fixed:
    Concern - Customer hears a rotational squeak coming from the R.R. brake. Gets worse if there is moisture/rain. Started happening around 2k miles. Please inspect and repair as needed.
    Cause - Verified noise from rear brakes, tech found lack of lubricant on rear brake support plate and shims.
    Correction - Removed rear brakes--lubricated with brake grease, backing and support plate--shim kit as well. Re-installed and no longer making noise after repair.
    As of my drive to work this morning and moving out of my garage, there is no more squeak. Hopefully this fixes the issue. If it comes back, I guess they can redo this again, but as I can hear this every day and have not heard it since, I hope this fix works for a long time.
    I hope this helps all of you as I know how annoying the wheel squeak is and mine was very loud and happened after every time I restarted the car after being idle for more than a few minutes.
  17. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Well I think it's minor so possibly why it does not get mentioned. I notice mine each day does it for a little bit while backing out of the garage, down the driveway.
    I did note though, that once driven and you back up later NO SQUEAK. So I suspect dampness, or something, but have no brake issues with my car at all.
    So, I am not overly concerned at this point. Just will monitor. ;)
    Similar to PAKITT's response.
  18. hansgrason1
    hansgrason1 Member
    104
    Washington D. C.
    Well, I'm not at all surprised! I have been to the dealer on two occasions in the last 5 months and neither time could they hear anything. We are sooo screwed!
  19. spwolf
    spwolf Senior Member
    3,156
    440
    Eastern Europe
    it would be interesting if it goes away in another 5000 miles, or possibly get worse ;-). If the squeak is not that bad, dont get too worked up, it will take a while for them to figure it out... usually it could be dust clogging support plate/shims. It happened to european Auris for quite a while, took them a while to fix ;-)
  20. hsiaolc
    hsiaolc New Member
    617
    46
    UK
    I had the same squeaking sound from one of the wheels dring rolling start from the very beginning. However, after a while it is completely gone now. Hope it doesn't come back.
