Squeaky Brake Pedal? Have tried WD40 but can’t seem to find exact spot to spray.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mainestreamrob, Apr 15, 2021.
  1. mainestreamrob
    mainestreamrob Junior Member
    22
    Hello! I am looking for advice on how to fix this squeaking noise coming from my brake pedal. It’s been going on for months and starting to get super annoying. I am certain it’s coming from somewhere in the video(brake pedal components) yet I’ve sprayed WD40 into the black rubber bushing and on a few other components and nothing has seem to done anything. Does anyone have any suggestions? Also I am not referring to the humming noise, specifically the squeak. I’m about to give up..
    2007 102K
    Thanks!
  2. mainestreamrob
    22
  3. kmsbanr
    kmsbanr Junior Member
    31
    I saw this after reading your post in a recommended box of videos to watch next on YouTube. It's from O'Reillys and the clutch sounds like your pedal. Hope it helps..
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,783
    2017 Prius c
    The original poster actually has been on here fairly recently so he might see your answer.
    NOTE: Original formula WD40 is NOT a good lubricant.
    It was not designed for that.
    kmsbanr and Meg&Bear like this.
  5. dolj
    dolj Senior Member
    7,510
    3,774
    Wellington, New Zealand
    Second Sam's comment. Original formula WD-40 will dry out the connection surfaces and make the squeaking worse over the long run. Use a proper lubricant.
    Use something like spray on Lithium grease, or this:
  6. kmsbanr
    31
    I never saw your reply but appreciate it. Interestingly I had a muffler issue and they checked my brakes which needed to be done. To my surprise the sound went away! So if I ever have a noisy pedal when depressed I’ll know what it means. I’ll also remember about WD 40. Thank you
  7. kmsbanr
    31
    Great video Thanks!
