Squeaky Seats in Winter
Discussion in 'Gen 2 Prius Main Forum' started by ChiPri, Jan 29, 2007.
  1. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    My driver's seat has been squeaky since the day I got my Prius (factory installed leather). I too will have to check out that clip. I just figured I'd have to take it to the dealership, and I've been too lazy to do it thus far.
  2. Rest
    Rest Active Member
    1,210
    CA
    My passenger seat is still squeaking and it is now driving me nuts!
  3. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    I've had the same problem with passenger seat squeakiness. I bought my Prius last summer, so I wasn't sure if it was the cold, or just time and use loosening up some plastic parts.
    Looks like there might be a real solution developing though. I'll try looking for that plastic clip and report my findings as well.
  4. 4chi
    4chi New Member
    79
    I have this problem....can anyone post a pic of what I should be looking for?
  5. Ichabod
    1,794
    Newton, MA
    If I find that my problem is related to the same plastic part, I'll post a photo this evening.
  6. Rest
    Rest Active Member
    1,210
    CA
    If I push on the seat front, top or side the squeak stops until I let go. I can't seem to locate the exact spot it is originating from.
  7. Ichabod
    1,794
    Newton, MA
    So, I looked around under there, and I saw some yellow clips, but that didn't seem to be my issue. This image shows where my squeak is coming from. That's the right-rear of the seat, and it's where the plastic skirt on the back of the seat overlaps another piece of plastic. I lifted up the overlapping piece a little and the point of contact shows enough wear to convince me that's the source of my squeak. I haven't patched it yet, but I'm guessing a piece of tape or something either softer or with less friction will do the trick though.
  8. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    [attachmentid=6898]
    Try this and see if it helps.
    Wayne
  9. Rest
    Rest Active Member
    1,210
    CA
    I finally found a way to take the side plastic panel off the seat without breaking that one clip!
    Unfortunately I broke the clip before finding the solution. :(
    The cover that the clip is attached to has a screw on the lower seat side. Remove that screw and you can take both covers off together without having to break the clip.
    I put some black electrical tape on the inside cover. It was clear there was rubbing going on in there and causing my seat noise.
  10. abq sfr
    abq sfr New Member
    690
    Albuquerque, NM
    My '07 fabric seat does not squeak even when its cold. Maybe all you squeakers weigh too much, I only weigh 230 lbs :D
  11. Rest
    Rest Active Member
    1,210
    CA
