Squealing sound 2007 Prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Rikabi, May 27, 2019.
  1. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    Hi guys,
    I am new here :)
    So i bought a used Prius 2007 t3 with 100k and fully service history for my wife. And it drives a dream even considering its age! I am considering selling passat cc and getting one instead !
    However we noticed a sqeeling sound coming from the front tyres. It happens randomly, not very often. At low speeds or if i turn. It happen without brakes being applied. If i speed up it tend to disappear
    I got a video here with sound :
    Ive been told to change brakes+pads but with no guarantee the sound will go.
    Any ideas?
  2. Grit
    Grit Senior Member
    6,450
    4,186
    Wilkes Land
    Which ever wheel is squeaking, before jack the tire up off the ground, unplug 12v ground cable. Remove the wheel and get to the caliper tonchecknand see if a rock is between the pad and rotor. Then pull the caliper pins, wipe clean and lube them. Hopefully it’s semi seized caliper pen that needed lubing.
    Do that first if want to avoid new rotors and pads.
    Rikabi and Raytheeagle like this.
  3. Rikabi
    Rikabi New Member
    United Kingdom
    Active
    I would like add I didn't have the confidence to complete the above, so I got a mechanic to change pads/rotor for both front tyres (£100) and now I squeak free :)
