SSC50P like a new car!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by tomdeimos, Dec 5, 2005.
  1. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Haven't floored it yet but the "less responsive" seems to fit my description of it being less sensitive.
    Maybe the delay on flooring it is part of the fix to keep it running. Before my update if I floored it my car almost hiccup'd.
    My mileage has remained about the same at least in this cold weather slightly over or under 50 mpg.
    But it would be like yours down in the lower 40's without my block heater etc.
  2. tomdeimos
    995
    Lexington, MA
    The udate is supposed to cure the stalling problem on the highway that I never saw, but some here have experienced.
    But the code seems to change regularly, and this was a great excuse to get rid of the bad code my car seemed to come with. Virtually all the older cars seemed to get better mpg. That is why I am hopeful there will be some benefit next spring.
    The code roll back you mention is the THHT code not the update to the car. The other threads talk about having to load it with the older THHT code, so it goes in safely.
    As to safety, best to go to a dealer that has done lots of these. Beyond that waiting shouldn't really matter. If they do it wrong you need a computer swap either now or later. One reason to wait could be to avoid the rush and do it when the spare computers are back in stock if you are worried.
    I was suspicious of the code my car came with so was extra glad to get the update now. If you regularly get over 60 mpg you might want to not get it changed.
  3. Priioneer
    Priioneer Junior Member
    :angry: YES!
    This has been a most disappointing 'upgrade' (wish I'd never had this recall done).
    Actually, I believe I'd already had this (or similar?) recall complied with earlier.
    Shortly after the media was running with the story of some Prius stalling while driving (IIRC, this was supposedly due to folk not taking in the Prius for yet an earlier recall [ECU flash update] which should have prevented any on-road stalling). In any event, I mentioned to the service that I believe I'd already had this recall (ECU flash) completed; nevertheless they scheduled this latest and I had the "SSC 50P" completed on 14Nov05.
    Performance is clearly degraded. Off the line, I would usually accelerate briskly (okay, I keep it floored) until I reach the desired speed than back off and coast/feather to maintain speed. (Many moons ago, this was deemed the most efficient way to maximize mileage [still true?]). Unfortunately, after this 'upgrade', there is always a delay and the acceleration is not as hard (curve less steep). Additionally, there seems to be an even greater lapse when slowing/coasting and then trouncing the accelerator; this is most disquieting and creates a feeling of less safety.
    I've driven well over 100K miles between my Prii (~37K on the '04 [~98K on '01]) and was quite familiar with their capabilities and handling. Lately, I'm less confident when I need the car to quickly respond (e.g. passing or avoidance manuevers).
    I'd recommend others hold off on this 'ECU flash', (especially if you've already had the earlier and are comfortable/confident with results) until more information is known. This, of course, will also give your dealership more experience with this procedure. ...I'm wondering if mine was properly performed.
    Collect more info; consider your options; Good Luck!
    --Stephen
  4. tomdeimos
    995
    Lexington, MA
    I rarely have to floor my accelerator. However I do notice a big decrease in power in the winter. This is due mostly to the battery being limited till it gets warmed up, which it doesn't have time to do during my commute. If you drive an hour maybe it will get warm.
    So even with slow acceleration the rpms on the engine go way up over 3000 instead of 1800 and there is a big drop in feeling of power.
    I see this now but it is not any different before or after my upgrade.
    The extra delay on flooring it I could believe is the code. I will try it to see if mine seems different on that.
  5. tomdeimos
    995
    Lexington, MA
    First the good news. I have been noitcing the engine sounds diffrent since the update. I finally realized that especially during warm up it runs much smoother.
    The bad news is I can confirm what others have noticed. I have not floored it from a stop yet, but today I did it while going along about 30 mph. I noted the battery current went to a whopping 20 amperes! ( Not sure the normal warm limit here but it should be much higher. Today the battery was right at 32 degrees, and not doing much.)
    And I notice there is a new delay. After flooring it it took like 2 seconds for the engine to speed up! You sense the accelerator is totally disconnected from the engine. The only time previously I noticed sometihng like this was when I test drove the Honda Civic Hybrid, where it takes time for the bands to move on the cones.
    The engine sped up very smooth, and very slowly. I think maybe Toyota has overcompensated on this now. Should be possible to speed up the engine faster and still smooth, but I guess they want the NTSB to leave them alone, and were too cautious. I can see why it would bother everyone.
  6. Tideland Prius
    16,681
    oye... I've floored it twice - once to merge into an HOV lane and the other, because I felt like it and wanted to see how fast it accelerates with full throttle. With the first case, there was a lag already, in the second, not so noticeable.
    So tomdeimos, would you give this upgrade an overall yay or nay?
  7. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    There's *always* a lag, because the initial push comes from the
    battery [limited to 100A / 20kW, do the math for horsepower] and
    before the engine can produce the additional power required, it has
    to spool up to a high RPM, and that's still done gently because the
    motor-controlled throttle cannot really *snap* open and the ECU
    doesn't really want to do the huge-enrichment thing that would be
    required along with anyways. Understand your system and plan ahead.
    Now, some of tomdeimos' observations may have some coincidental
    relationship with colder weather. I'm noticing that various battery
    currents [both in and out] seem to have higher, longer bursts while
    the car is still cold -- such as charging up to 7 or 8 greens for
    no apparent reason, or letting me push 50 amps in stealth for brief
    periods before the ICE is actually warmed up and in stage 4. I
    wouldn't doubt that this is actually *stragegy* for getting the HV
    battery warmed up faster, since even with plenty of cabin heat it'll
    take a while for it to reach back there and go through the ducts.
    So more current == more internal cell heating, possibly at the
    expense of a little efficiency but long run, probably better once
    the pack is at a better temp.
    Oh, and no, I don't have SSC50P yet. May never, in fact.
    _H*
  8. tomdeimos
    995
    Lexington, MA
    Have to wait till summer to answer. If I can break out over 60 mpg for at least 1 tank I might accept it.
    But I hope Toyota can fix this better next rev, if enough complaints come in, but still leave the new engine to elelctric motor settings that I think will help mpg on back roads.
    With the old code the best tank I got I think was 57 mpg driving mostly under 55 and lots of 30 to 40 mph.
    For now I will pretend when I accelerate I have a jet plane and have to wait for the turbines to speed up!
  9. Tideland Prius
    16,681
    Hmm, that can be a bad thing if you need to get out of sticky situation, fast!
    I got 54mpg as the best tank (oh so close!) this past summer.
  10. tomdeimos
    995
    Lexington, MA
    OK tonight I accelerated again and had the battery warmed up a bit to over 40 deg.
    This time I pressed the accelerator fast but not slamming it down, and I got a more rapid engine speed up. Battery current went up to over 50 amps too.
    I think I can get used to it, but that may be because I drove a slow diesel before and had to shift and then wait forever to go faster. Prius is still about 50% faster accelerating.
    And from my highway drive tonight I think my mpg is doing better. I am comparing to the palm simulator for temp correctons. In summer I could never quite get what it said I should. Tonight at 23 degrees I was able to beat it by a bit.
    I drove a loop at about 50-50 65 mph and 55 mph. Got 52 mpg overall.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have to say that we can figure this out. First we need to collect some data. These anecdotal posts are nice but the only thing that they say is we need to collect data.
    #1 if you have been collecting data on your actual MPG before the switch you are in. Now you need to keep collecting data.
    #2 The USWS collects data on average temp data high and low we need to corollate that.
    #3 We need to collect data after the flash. Hopefully we need Summer, Winter data, depending on when you got the flash.
    #4 we need to compare the data to see if there is a difference
    some variable that come to mind that we might whish to control for: driving style description, i.e. "Totally coast and glide using the energy screen, ScanGage, CAN View, and anything else I can get ...Prius Master", "Milage improving still using the consumption screen.... Intermediate driver", "Milage OK this is a new car and I am just breaking in the car I am still using the Energy screen and am amazed by energy transfer in this car".... Prius beginner, "I am dazzled by the information, have not finished the owners manual, Wow".... Prius novice.
    #5 after driving style there are other variables, like radiator screen, engine insulation, block heater, use of alternative data source, i.e. see above CAN View etc.
    #6 you supply what ever we need to control for.
    Then we collect the information and compare it.
    I will be getting my flash at 25K, with oil change etc and will keep folks posted. I would suggest we need a few months before and after the flash, as well as past history if we have it.
  12. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    I may have more miles on my car since the SSC50P flash than most, since I took a 2000 mile roadtrip on the car right after the flash. Here's what I noticed.
    Initially, (first 1000 miles), the car kept the battery near a full SOC, something new. With highway driving it would almost always stay green. In the past it was normally around 4 bars. The car did seem to get a bit lower mileage (about 3mpg lower) and a bid slugish.
    At about the 1000 mile point things got back to normal. The SOC went back to the typical 4 bars, mileage went back to normal, and performance seems normal now.
    Of course this week winter hit with a vengance and it is now 2 degrees out and I'm driving in snow on Blizzaks, so I can't really judge anything any more.
    My best guess is that after the flash, the car goes through some sort of battery conditioning or gauging routine, then settles down to normal.
    That''s how it worked on my car, ymmv!
  13. Tideland Prius
    16,681
    so like.. another break-in period so to speak?
  14. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    sORRY BUT WHAT IS SSC50P?
  15. tomdeimos
    995
    Lexington, MA
    OK, in collecting data we need to get past 1000 miles first, because I can believe there is a new break in immediately after the flash. I too am getting higher green set pt. but I had that last winter too due to the temperature drops. Can't say how much if any is the code update.
    Another factor in data collection is everyone needs to identifiy what their prev code was or the car's build date. The data already here shows the early cars got better mpg already.
    I got my car in Dec 2004, and I will have to check the build date.
    I'll try to gather more data and post in the economy mileage area.
  16. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I would call it a 'learning period' rather than a 'break in'.
    It's not unusual for modern cars, not just the prius, to 'learn' patterns in engine management, and after a 'reset' of the computer they have to relearn them.
    Some modern cars even have adaptive transmissions that 'learn' your normal acceleration/shift patterns.
    It's to the point where you can get in two identical cars that have been 'trained' by different people, and they behave very differently.
    With the Prius, juggling all the variables of ICE/motors/battery/brakes, it's a complex equation and would logically take a while to settle down.
  17. tomdeimos
    995
    Lexington, MA
    Right Tempus. Better name for it.
    And I believe the Prius does learn a lot! I amd still sure the car does battery mode more after I have used the EV button a little bit.
    It also seems to do the battery mode better after I have been in a particular kind of terrain for a while. If the road grades change, it takes a while to adjust to that too.
  18. bobkat21
    bobkat21 New Member
    99
    Elwood IL
    how do you get this info out of your car?
  19. tomdeimos
    995
    Lexington, MA
    Just notice what the car does, and when a pattern repeats most every time I consideer it a feature of the car.
    Of course this was with my old code, and so now I will have to start from the beginning again and see what it does.
    Battery mode is so easy now I don't expect to see the same effects any more.
  20. DanMan32
    DanMan32 Senior Member
    3,799
    27
    Tampa Bay, FL
    SSC-50P is Toyota's answer to complaints and symptoms of ICE failing to start. Also I think they folded in a fix for a false DTC regarding the MG position sensor.
    50P encompasses an update to firmware in the HV ECU and ICE ECM, as well as sealing a sensor connector with dialectric grease.
