Stainless Steel Rear Bumper Protector with LED install help
Discussion in 'Gen 3 Prius Accessories and Modifications' started by zvw30yuki, Aug 10, 2013.
  1. zvw30yuki
    zvw30yuki Junior Member
    Hello forum. I'm hoping someone can help me on the electrical wiring for this install. I purchased a rear bumper protector with LED from Japan. It came with no instructions. I looked all over the forum and unable to find anyone with this accessory, only the non LED version. Anyways the protector has a cable connector and a additional wire extension. There are only two wires. RED and BLACK. I'm planning to tap into the trunk light. I pryed the trunk lamp today and found a WHITE and RED color wire. My question is which wire should I tap into? My guess is tap RED to the RED trunk light wire, and BLACK to ground? If anyone can provide some expertise would be greatly appreciated. Thanks in advance. Below is a photo of the LED bumper protector.
  2. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Here is your request, On the harness, the RED is +Pos and the WHITE is -Neg.
  3. zvw30yuki
    Thanks for checking on this. So the case here is, Tap my RED wire to the RED trunk light wire and ground the BLACK wire to the chassis?
  4. NoMoreNow
    NoMoreNow Member
    167
    102
    SF Bay Area
    Yuki, just Ground the BLACK wire with the WHITE wire is fine.
    So you have the RED (+) & BLACK (-) in one place by the harness.
  5. BigPete
    BigPete Member
    149
    55
    Plymouth, UK
    Got a link to it as need one like this but with white led preferably as have the white door sills.
  6. zvw30yuki
    Thanks. I'll do the install tomorrow and post pics.
  7. zvw30yuki
    I bought my on yahoo.jp auctions. You can copy/paste this to the search: "プリウス リアバンパーステップガード LED"
    However it appears only blue led is offered. Works out well for me because I have the USDM illuminated blue door sills that match. Maybe you can replace and solder in white leds.
  8. zvw30yuki
    Installed it this morning. Ran the wire along the existing loom behind the panel and tapped into the trunk light. Satisfied with the protector, especially for the price paid.
    nedear88 and NoMoreNow like this.
  9. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    And how much was that?
  10. zvw30yuki
    5900 JPN yen. That's roughly $60. Then reshipped from the inlaws in Japan to the states about which cost about $30 via SAL. Still cheaper than the JDM oem Toyota elegant version which sells for 11550 yen ~ $120. Plus this one has an LED and the oem one doesn't.
    spiderman likes this.
