Stall in San Fransisco
Discussion in 'Gen 2 Prius Technical Discussion' started by Stalix, Feb 11, 2007.
  1. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Stalix @ Mar 16 2007, 10:39 PM) [snapback]407285[/snapback]</div>
    Ha. It must be nice to have a spare Prius, so you can swap parts for troubleshooting or fixing.
    Dave M.
  2. bwilson4web
    16,531
    <div class='quotetop'>QUOTE(Stalix @ Mar 17 2007, 12:39 AM) [snapback]407285[/snapback]</div>
    Excellent!
    Do you still have the bad pump? I know some folks who might be interested in taking it apart. Send me a PM and we can work out the logistics.
  3. Stalix
    Stalix New Member
    Well I put the "supposedly bad pump on my "spare prius" and it works great there. so now I have two good working pumps.
    Maybe the bad pump only goes out after long use?
    Anyways I'm just hoping the problem is solved, I constantly check my coolant tank to see the stream of the pump is nice and strong now and has been ever since I put it on.
    so the only way I'll be calm is when 3 months go by without incident. Because the problem surfaced approximately by one month intervals.
  4. bwilson4web
    16,531
    <div class='quotetop'>QUOTE(Stalix @ Mar 18 2007, 03:32 AM) [snapback]407795[/snapback]</div>
    If you're lucky, it was a connector problem. Reseating the connector will clear the problem and it may go for a long time before it needs to be reseated again.
    GOOD LUCK!
  5. brick
    brick Active Member
    1,083
    79
    Upstate NY
    A little dielectric grease on the pins might help to keep things clean if it's really just a connector problem. If moisture is getting in there, it could be as simple as a little corrosion.
  6. Stalix
    Stalix New Member
    if it is moisture it would explain why it happened in San Fran, because the weather was terrible and rainy and humid.
    eh, whatever I don't care as long as it don't happen again.
