Standard Prius Prime Charger (G9060-47130) supporting 240V
Discussion in 'Prime Plug-in Charging' started by Carsten Steenberg, Jan 9, 2018.
  1. Rmay635703
    Rmay635703 Senior Member
    2,675
    1,703
    Somewhere in Wisconsin
    2013 Chevy Volt
    Resale ?
    I see your post with the adapter?
  2. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    No, I see it.
    You need to turn off all ad blockers & filters, if I leave my ad blockers on, I can't see it either.
    Rob43
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    You mean post #175? It's still right there. Looks like this.
  4. BillKoz
    BillKoz Junior Member
    29
    23
    Hurricane, Utah
    2019 Prius Prime
    My bad, thanks!
    jerrymildred likes this.
  5. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    Adapters are NOT the same as EVSEs. Those prices are reasonable for DIY ADAPTERS.
    Arctic_White likes this.
  6. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
    I know that.
    Did you see I post a link to a EVSE on amazon for $200?
  7. hill
    8,981
    Found a volt portable L1 at a garage sale & picked it up for dirt. Made up an adapter real quick & boom shakalaka - it works. It got warmer than my comfort, not even looking like it's 12 gauge wire.
  8. Billy sharpstick
    Billy sharpstick Junior Member
    Micanopy FL USA
    2019 Prius Prime
    My brand new one has the same specs printed on it. I suspect that is the maximum factory rating for the plug itself, which is more or less an off the shelf plug.
  9. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    One bit of strong evidence here is that no one has come forward saying that they did this and their EVSE fried or exploded. I’m sure that if this happened to anyone they’ll be the first to post about it.
    iPad ?
  10. rhfritz
    rhfritz Junior Member
    33
    2018 Prius Prime
    :) I appreciate all who have contributed here.
    #190 rhfritz, Jul 29, 2019
    Prius from Dad likes this.
  11. hill
    8,981
    one very serious caveat here. Just because these EVSE's are capable of sending 3.6kW's to our plugin's on-board Chargers, do NOT attempt to use these modified EVSE's on plugin's that pull more ... 6.6kW's-10kW's. Pulling 30 amps on 12 gauge wire is a guaranteed recipe for disaster.
  12. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    NOPE.
    I've tested the OE Toyota EVSE and another automakers OE EVSE (both at 240v) on a bigger battery EV car that is designed to take a 32 Amp EVSE, both OE 120 volt units only put out ~12 amps as they are designed to do through their 12 AWG cord.
    12 Amps is the maximum that any of these OE 120v EVSE units will output,....Period.
    Rob43
    #192 Rob43, Jul 31, 2019
    mveras1972, rhfritz and jerrymildred like this.
  13. hill
    8,981
    Period
  14. rhfritz
    33
    2018 Prius Prime
    Hi Rob, I can't see how to PM you. PM me and I'll reply.
  15. mveras1972
    mveras1972 Member
    173
    63
    New Philachussetts
    The Prius EVSE specifies the wires it has inside, one 12 AWG and two 14 AWG.
    As I understand it, 14 AWG supports up to 15A while 12 AWG supports up to 20A.
    iPhone ?
  16. jjs357
    jjs357 Junior Member
    50
    Near Philadelphia PA
    2020 Prius Prime
    Will the EV Doubler 120V product work when the two 120V plugs are being fed by the same wiring? I have a patio with an outdoor AC outlet with 2 sockets. These seem like they are meant to be outdoor -- they have caps. Can I combine the feeds from them safely and feed the standard Prius level 1 charger? This is one of the other products that the original Amazon link connects to.
  17. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Nope, they will not work when fed from the same wiring/circuit.
    Rob43
    jerrymildred and jjs357 like this.
  18. jerrymildred
    11,517
    14,164
    Tampa, FL
    You use that device by plugging it into a 240V receptacle. The you plug your "120V" EVSE into it. Looks at the plugs; that's the only way it can work.
  19. mo prime
    mo prime New Member
    Jordan
    hi there i live in Jordan its provide 220 v in country and i bought prius prime 2017 , i read all instructions and yours comment but i plug the charger with grounded wire in the car , for second it seems charged but thin it disconnect and get fast blinking green light what can i do in this situation !!!!!!??
  20. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Hello, and welcome to PriusChat !
    Can you please take a high quality close up picture of the label/sticker on your Toyota EVSE unit and post it up here.
    Rob43
