Standard Prius Prime Charger (G9060-47130) supporting 240V
Discussion in 'Prime Plug-in Charging' started by Carsten Steenberg, Jan 9, 2018.
  1. hill
    8,802
    Maybe the most expensive / heavily optioned versions get the better charger? That's how it is with the rav4 prime.
    Maybe that's why sites like Edmunds says otherwise;
    #321 hill, Oct 31, 2023
  2. Louis19
    Louis19 Active Member
    392
    369
    Laval Québec Canada
    2022 Prius Prime
    Upgrade
    ....Edmunds should read the 2023-2024 Prius prime manual ....before publishing see post 320
    #322 Louis19, Oct 31, 2023
  3. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    So the gen 5 went to 3.5, good source.
    What I am finding is any old wall outlet is not necessarily at 120 volts under a 12 amp load, if that is the supply voltage from the utility. I think most people myself included think a wall plug is a wall plug and works fine. Not true.
  4. Bill Norton
    Bill Norton Senior Member
    2,149
    734
    MONW, Ks.
    Sorry, I thought you were asking if you could 'adapt' an L1 EVSE to use it on 240V.
    If you already have an L2 EVSE with a 240V connector and a dedicated 240V outlet to plug into,,, You're fine.
    What was the question in the first place?
  5. Bill Norton
    2,149
    734
    MONW, Ks.
    Now what are you talking about?(n)
    A 120V outlet is always on, at the very least, a 15A circuit breaker, possibly an 20A.
    And that is why EV manufacturers selected 12A as the max an L1 EVSE can pull. The 80% rule.
    Some manufacturers have the car default to 8A for safety/lawyer reasons, and you must select the car to charge at 12A on an L1.
    Are you talking about the voltage 'sag' under load? That always happens. Open voltage vs Full Load voltage.
    Are you talking about old outlets having their sockets not providing the 'Pin Grip' on the plug?
    That is an issue, true.
    And that is why some EVSE manufacturers have a temp sensor in the plug to tell if the conductivity through the connection is bad and heat is developing.
  6. Bill Norton
    2,149
    734
    MONW, Ks.
    Stupid site.......
  7. Mr.Vanvandenburg
    1,352
    571
    2020 Prius Prime
    This. Yes I have a cheap 240 v evse from Amazon. I wouldn’t adapt my expensive Toyota one to more as it says 12 amps on it. Others say it works, that’s their decision. I’m not adapting the $100 Chrysler one I bought either, even if people say they did it on Pacifica forums. I don’t know how making the neutral into a hot works inside the evse, and now don’t need to know. I like the Chrysler one, pretty nice.
    https://www.macheforum.com/site/threads/how-to-test-if-an-120v-outlet-is-safe-for-charging.16909/
    #327 Mr.Vanvandenburg, Nov 1, 2023
    Bill Norton likes this.
