Standard Prius Prime Charger (G9060-47130) supporting 240V
Discussion in 'Prime Plug-in Charging' started by Carsten Steenberg, Jan 9, 2018.
  1. tlessard
    tlessard Junior Member
    Austin
    I checked mine with my laser pointer temp gun and got almost exactly the same results this afternoon. My garage floor slab was at approximately 63 degrees, the dryer cable to 10-30r hot-hot-ground wired outlet was the same temp, 5-15 adapter and EVSE plug end were at 64 degrees the entire time, and the brick went from 65 degrees at start to 71 degrees at the conclusion of the charge, which took under 90 minutes on the PIP. Obviously, none of it is warm to touch because it is below body temperature, but it’s nice to see some corroborated data on the temperature delta.
    Rob43 and jerrymildred like this.
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,151
    Tampa, FL
    Using those infrared thermometers is always a good idea after a wiring job. In fact, it's good to do that about once a year in the breaker panel and other places anyway. When I was an industrial electrician our insurance company had someone come in once a year to check our whole plant with an infrared camera. Thousands and thousands of connections!! They always found a few that had loosened up.
    Arctic_White and tlessard like this.
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Someone hooked the modified Prime EVSE to a Tesla, and it reported a charge rate of 12A at 240V. My Chargepoint charger reports a charge rate of 3.6KW, which is 15A @ 240V, and takes almost exactly 2 hours for a full charge. It appears that the Prime EVSE always advertises 12A, whether at 120V or 240V. The charge rate can be reduced to 8A with a setting in the Prime multi-function display. So the modified EVSE will be just a little slower than a "real" 240V charger (like 20%), but the "price is right".
    #163 CharlesH, Mar 30, 2019
    Arctic_White, tlessard and Old Bear like this.
  4. Peng Xiao
    Peng Xiao Junior Member
    84
    New Jersey
    2018 Prius Prime
  5. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    As it should, it has a UK specific plug on it, not NEMA 5-15 like the US.
    Arctic_White likes this.
  6. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    Someone mentioned before UK having the same part number as US. I just want to point out they are not.
  7. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    As I recall, and my memory is bad, they opened them up and the part number of the circuit board is the same.
  8. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    The reason for this is because the moment Toyota needs to stick a different (UK) plug end on the charger, the chargers part number needs to become slightly different.
    Absolutely correct.
    Rob43
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Arctic_White and mountaineer like this.
  10. Richard Merwyn
    Richard Merwyn Junior Member
    napa, ca
  11. Richard Merwyn
    napa, ca
    Thanks! Your comments make sense to me even though they depend primarily on inference, deduction and logic - not to mention some physics. It would seem that the reports of successfully connecting 240V (properly of course) to the OEM EVSE without SMOKE!!! remains the primary evidence. What would be wonderful would be if someone with true EE qualifications could do a teardown and analysis of the circuit design, and materials. But that would most likely be a destructive teardown and who has the $$$ to sacrifice his/her equipment, eh? Since I usually do a nocturnal 120 slow charge and don't really need the fast recovery of a fast charge think I will wait until more "evidence" is accumulated - or my needs change...
  12. Richard Merwyn
    napa, ca
    I'm sure that Toyota Inc is not about to authorize this retrofit, or provide support of any kind or form. Ever. Think of the possible liability issues if some dufus screws it up. And I would wager that 99% of the Amurkhan Public doesn't have a clue of about basic electronics/
    - or if they think they do, they really don't. Big Corporations are just Big Targets for lawyers...
  13. Digloo2
    Digloo2 Active Member
    124
    132
    Phoenix, AZ
    It has been over a year now since I got my 240V adapter set up and I have been using it to charge my PIP daily at Level-2 voltages.
    I've had absolutely no problem with anything involving the power.
    It takes 2-1/2 hours to fully charge from empty if it's not over 100F outside. (It seems to slow down as the outside temps go up.)
    #173 Digloo2, Jun 3, 2019
    Arctic_White and Rob43 like this.
  14. PriusInChargerOnly
    PriusInChargerOnly New Member
    San Diego
    2017 Chevy Volt
    Arctic_White and Rmay635703 like this.
  15. BillKoz
    BillKoz Junior Member
    29
    23
    Hurricane, Utah
    2019 Prius Prime
    works great!
  16. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    $70 for an adapter only, worth it while a level 2 charger is $200?
  17. Digloo2
    124
    132
    Phoenix, AZ
    Why not give it a try? BTW, where are you finding L2 EVSEs (they're not "chargers") for $200?
  18. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    The Chinese built 16 amp EVSE units from Ebay & Amazon like Duosida typically cost between ~$165 to $200 depending on the plug needed & length of cord given. A 240v Pigtail adapter at $70 for 12" to 18" inches using 12 AWG wire does seem a bit high priced, I build most configurations using thicker 10 AWG or Really Thick 8 AWG wire for much less.
    Rob43
    #178 Rob43, Jun 7, 2019
    Arctic_White and jerrymildred like this.
  19. Peng Xiao
    84
    New Jersey
    2018 Prius Prime
    I do have 2 DIY adapters, 4ft and 20ft, using dryer outlet. Cost $16 and $52.
    #179 Peng Xiao, Jun 7, 2019
  20. BillKoz
    29
    23
    Hurricane, Utah
    2019 Prius Prime
    Why was my post about an adapter for the Toyota charger deleted?
