Standing Water in Tail Light Lens
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by moonlightVFR, Oct 8, 2016.
  1. moonlightVFR
    moonlightVFR Junior Member
    I
    For about a year I have 3 - 4 inches of water in Left Rear Tail light lens
    Has any other owner seen or heard of such an event.
    20012 Prius C 34M miles.
    The left back up light is burned out. Obviously shorted from being under water.
    I welcome any suggestions.
    Regards
    moonlightVFR
  2. cutter44
    cutter44 Member
    213
    MA
    You're not alone. Water in taillights | PriusChat
    I had it when I bought the car and they replaced the right taillight before I took delivery. I subsequently cracked the left taillight (my clumsiness) and I replaced it. A couple of months later, I noticed a little water in the bottom of the one I replaced. I followed the lead of someone in that thread I linked to and drilled a small hole in the bottom of the lens. No more standing water now...although I do notice them fogging up occasionally. :)
  3. moonlightVFR
    I
    That you for your comment.
    Now i know it could and has happened to others.
    Drill small hole for drain will work .
  4. Paul odonnell
    Paul odonnell New Member
    Los Angeles
    My Prius C has the exact same problem I'm waiting to see if Toyota is going to fix it for me under their Goodwill because I'm past the warranty I will keep you posted
  5. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    I still have a drivers side light if anybody is interested. It's boxed up and ready for shipping. I had it on the car for around 6 months before I went with the Blacked out lights. Did not leak in that time.
  6. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    But a better solution is to give the whole assembly a thorough inspection to see WHY the water is getting in there.
    If those bulb sockets rust and corrode, your tail/turn/brake lights might blow a fuse and stop working.
    Deimos13 likes this.
  7. staryla
    staryla Junior Member
    US
    2014 Prius c
    I bought a 2014 Prius C a few months ago and have standing water and a burned out reverse tail light on the passenger side.
    While stopped at a red light I noticed a similar Prius C in front of me had a few inches of water sloshing around as well.
    I might be going the small hole route. How bizarre.
  8. John in Vermont
    John in Vermont Junior Member
    32
    Rochester, Vermont
    2018 Prius c
    My brand new 2017 C has had both taillights replaced under warranty for water leakage.
  9. nhtech
    nhtech New Member
    Highland, Il
    I had that same issue on the lt taillamp, on a 2013 Prius C my daughter bought, I removed the lamp, replaced the burned out bulb, deied the lamp, then resealed the lamp lens , took care of the water issue. Seems they have a bad seal on the lens that's causing the water to enter the lamp.
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,173
    2,213
    Taylors, SC
    Temporary solution is to drill a 1/4 inch drain hole at the lowest position at the tail light where the water is. This will result in less damage that standing water in the taillight.
    Permanent solution is to replace it.
  11. Dave in Ky
    Dave in Ky Junior Member
    Northwest Ky
    Yes, I've had the same issue, first left side then right side. Both tail light seals between the clear lens & black frame failed. I removed the asm and used clear caulking to seal the gap. Ended up replacing both.
  12. ztanos
    3,339
    1,149
    40
    Cumming, Georgia
    I still have a drivers side boxed up, ready to ship. Just waiting on the right person. :D
  13. Karen K
    Karen K New Member
    Maryland
    What’s the price??
  14. RobAustin
    RobAustin Member
    104
    51
    Austin, tx
  15. Campbell
    Campbell Junior Member
    Rochester, NY
    I had the same thing in my Prius C 2012. Went back to the dealership (it was supposed to be under warranty). They told me I had backed up into something and it must have been my fault. So I paid to replace it. Now, 11 years later, same back lamp is full of water again and bulb is out! I am going to try the drill a small hole approach. Wow. looks like this is a common issue
  16. Kerrynzl
    Kerrynzl Junior Member
    New Zealand
    2016 Aqua
    Pull the taillight out , and drill a hole in the underside at the lowest point [nearest the outer edge and the hatch]
    It will be totally hidden when re-installed
    Any water runs out onto the bumper cover
    I would guess that the seal issue is caused by cold weather
  17. Campbell
    Rochester, NY
    I did that first. Drilled a small hole and empty the goldfish bowl (as someone else called it). But I went ahead after it was dried out and took the whole thing off, put cement/glue sealer around the edge and put it back on (and sealed up the hole I drilled). I can see now why the lights fill up - the edges stick out a bit from the side of the car (will upload pictures later) and so any water you drive into will be beating right on the edge of the housing (where the outer clear plastic housing meets the inner plastic backing). My light looks trashy though as it has dirt in the housing... when I get up more energy I will have to take it completely off and wash it out then put it all back on. right now I just want to make sure there are no leaks.
