Stanley Fat Max 700 won't take a charge
Discussion in 'Gen 3 Prius Main Forum' started by Taxi/Limo, Oct 26, 2019.
  1. ASRDogman
    ASRDogman Senior Member
    8,055
    4,084
    Do you have a VOM? You can check for continuity in the wires.
    And test for voltage at the battery, before, and after putting the charger on it.
    What is the battery voltage?
    If you don't have a meter, you can use a test light and see if it lights, and how bright it is.
    Maybe the original battery was/is not bad, maybe the charger is.
    Or the connector on the device. Maybe a broken wire?
    Try another charger, that has a similar connection.
    SFO likes this.
  2. Taxi/Limo
    Taxi/Limo Active Member
    526
    107
    I don't have a Volt meter right now if that is what you mean
    I am trying to get one on ebay once I do I can test
    Not sure how to do a continuity test
    Not sure what you mean another charger has a similar connection
    Thanks
  3. ASRDogman
    8,055
    4,084
    The charger for your device may be broken, and not charging the battery.
    If you have another 12 volt charger, you can plug that one in and see if it charges the battery.
    Continuity is where you put the meter in "ohms" and touch the leads to the ends of the
    the wire (without power) and it should zero out, and probably beep. Meaning the wire is good.
    If you put the meter on the battery, note the voltage, then attach the charger, the voltage should go up.
    If it doesn't, either the charger is bad, or a wire is broken somewhere.
  4. kc5dlo
    kc5dlo Active Member
    266
    164
    DFW TX
    2021 Prius
    #24 kc5dlo, Jan 14, 2020
    ASRDogman likes this.
  5. ASRDogman
    8,055
    4,084
  6. kc5dlo
    266
    164
    DFW TX
    2021 Prius
    If you have an android device, The app in the link i provided has most all the coupons including ones from their Inside Track Club. It is searchable as well.
  7. Taxi/Limo
    526
    107
    Thanks Gentlemen I am looking for a Fluke Multimeter
    kc5dlo likes this.
