Start-stop button circuit diagram? Push Button kill switch>
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Georgina Rudkus, Sep 6, 2022.
  1. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
    Does anyone have the circuit diagram for the Start-Stop button?
    A simple kill switch in the wiring harness to the start function would keep the car from starting.
    It very low 5 volts, so a small micro switch will work. It could also be a hidden micro push button that needs to be held dowi with your left hand finger to complete the circuit to start the car. Because it is a momentary push button, it will automatically reset after each use.
    An enterprising company could make an adapter kit with the appropriate wiring blocks, wiring and switches for a simple install like drilling just one 1/4 inch hole in an underdash panel for the micro push button switch.
  2. Georgina Rudkus
    3,576
    2,605
    Taylors, SC
    Found this information. Would make it easy to wire in a kinn switch.
    The 3rd Generation (2010–2015) Toyota Prius Push Button Start switch (connector C17) relies on a 7-pin connector. The switch contains dual momentary contacts and built-in LED illumination, acting as a low-current trigger for the Power Source Control (Smart Key) ECU.
    Connector Pinout (Toyota Switch)
    Pin # Wire Color Circuit / Function Notes
    1 Light Green or Violet Ground for LED Completes circuit for switch illumination
    2 Pink LED Illumination Power (+) +12V power for switch internal light
    3 Light Blue Switch Status Ground Used for ECU to detect switch state
    4 White Switch Contact 2 (SW2) Second independent signal/ground to ECU
    5 White Switch Contact 1 (SW1) First independent signal/ground to ECU
    6 Green Unused / Spare Often used for specific trim diagnostics or security
    7 Gray Immobilizer/Key Check Signal wire verifying valid fob is present
    (Note: Wire colors can slightly vary between production years; always verify with a multimeter before splicing.)
    Important Considerations:
    • Dual-Switch Design: The Prius uses two separate, redundant contacts (SW1 and SW2 on Pins 4 & 5). Both must close simultaneously (full stroke) for the hybrid system to process the button press.
    • Immobilizer Lockout: Simply applying 12V to these pins will not start the car. The signal must be processed by the Smart Key ECU, which actively checks for the presence of a valid key fob within the cabin.
    #2 Georgina Rudkus, Jun 17, 2026
