Start TPMS sensors sending
Discussion in 'Gen 3 Prius Technical Discussion' started by our1vue, Oct 11, 2012.
  1. our1vue
    our1vue Member
    313
    58
    NY
    Hi all,
    I'm working on getting snow tires/steel rims for the winter for my 2012 prius. I know you have to enter the RFID of the sensors into the car's computer. But is there something you need to do to the sensors themselves to start them sending the pressure transmissions ? Thanks for any help
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    780
    310
    Maine
    We use summer tires and separate winter tires [with studs].
    Only our summer tires have the sensors in them.
  3. David Beale
    David Beale Senior Member
    5,963
    1,990
    Edmonton Alberta
    I believe the sensors send once the wheels start moving.
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    See TPMS initialization instructions attached below.
  5. ForestBeekeeper
    780
    310
    Maine
  6. our1vue
    our1vue Member
    313
    58
    NY
    ForestBeekeeper,
    Tirerack has a price of $220 for a set of 4 TPMS. Our local Advanced Auto Parts has the dorman for $92. I read somewhere in this forum that someone had gotten the Tirerack TPMS to work after they had entered the correct RFID number in the car computer. They had to go to a dealer since Tirerack had written the wrong RFID number on the receipt they sent them.
    Stream,
    Wow, that PDF is very interesting. If I read that correctly, you don't need the scan tool to tell the computer the RFID tags. This is the same procedure that Chevy uses on their cars when you put a new TPMS valve stem on their cars. I remember reading that the American car companies had a procedure for the car to learn new TPMS RFID without the need of a scan tool and the Asian car companies required a scan tool. I wonder if Toyota adopted this procedure and
    it is not widely known. Anyone try this procedure on their 2010 prius ?
    ForestBeekeeper likes this.
