Starter Battery
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tone Le Lone, Apr 22, 2021.
  1. Tone Le Lone
    Tone Le Lone New Member
    Los Angeles CA
    Hello All.
    I just had my car, 2011, towed home, and the lovely tow truck driver told me that the problem was the 'starter battery'.
    I had been getting gas, and upon getting back into the car, I turned it on but it would not go into drive.
    I also had trouble turning it off.
    Finally it turned off, and then when i started it again, which was an effort of button-pushing, I couldn't put it in drive.
    And I think a couple of times it started itself.
    It was like a possession!
    The tow truck guy said he put some charge in the starter battery, and then he drove it up on to the truck,
    He says I have to buy said starter battery and have it installed.
    Does someone have advice on which one to get, please?
    I don't want to show up at Pep Boys or somewhere with no idea of what I am looking for.
    Thank you very much in advance for any advice.
    I realise I put a pretty lame non-descriptive title.
    My apologies
  2. Samuel Williams Jr
    246
    Dayton NV
    Oh you did just fine. And it sound's like it is the 12 volt battery?? Starter Battery, how long has it been in there and how often is the car driven???
  3. Tone Le Lone
    Los Angeles CA
    Hi Samuel.
    I think it's the 12volt battery.
    I have had the car for 5 years and have not changed the battery.
    I drive the car almost every day.
    I called AutoZone and they sold me the attached battery.
    Not sure if it's the correct battery.
    52,703
    just grab an oem from toyota, $200. are you going to install it?
    wherever you chose to buy it, they will know what you need from the make, model and year.
    tell them you need a new 12 volt battery, keeps the 'failure to communicate' at a minimum :cool:
    Samuel Williams Jr likes this.
