Starting problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lancenz77, Jun 12, 2018.
  1. Lancenz77
    Lancenz77 New Member
    Florence, SC 29501
    I
    I accidentally crossed the positive and negative while jumping my Prius. Replaced fusible link. Car will start but then shuts down
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Which fusible link the big 100 amp one under clear plastic in the fuse box?
  3. Lancenz77
    Florence, SC 29501
    I
    Yes also replaced dome fuse. Electric engine starts, but I dont think gas engine is starting.
    49,708
    does the ready light come on? is there movement in the inverter reservoir?
  5. Lancenz77
    Florence, SC 29501
    I
    Could it be a relay or a fuse?
  6. Lancenz77
    Florence, SC 29501
    I
    Ready light comes on.I dont know what the inverter reservior is.
  7. bisco
    49,708
    the owners manual shows it. it is up against the bulkhead under the hood. make the car ready, unscrew the cap and see if there is any movement in the fluid.
  8. bisco
    49,708
    try disconnecting the 12v negative for a minute, then press the start button 3 times with your foot on the brake.
