Starting problems
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by vivamom, Feb 7, 2011.
  1. vivamom
    vivamom Junior Member
    Pennsylvania
    When the car worked, it had no problems cycling through any option. When it was dead, totally dead. They told my husband today they think it is the power switch and it will be ready Thursday. We will see......
  2. Patrick Wong
    18,210
    6,523
    The POWER switch is the cheapest and easiest item to replace. Should you find that the problem persists, the next question would be whether the problem can be replicated on demand. For example, do you find that when the weather is quite cold, the car may fail while in warmer weather the car works reliably. A loose solder connection would result in intermittent operation that may come and go as the temp changes.
    If that is the case, then one way to narrow down the problem would be to cool down the suspect ECUs, one at a time, to see if the problem can be induced. There are chemical sprays that can do that - or put a Baggie full of ice on the part. Then use a hair dryer (or heat gun) to warm up the part, to see if the problem goes away.
  3. vivamom
    Pennsylvania
    Not ready Thursday...the switch is backordered. They gave me a 2011 Corolla as a loaner on Friday and said they hope it will be ready by the middle of next week.
