Starting the prius after a year
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by whyheellothere, Jun 5, 2012.
  1. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    In this scenario petrol in liquid form does not compress either. hydraulics use oil. Diesels use oil. The amount of liquid injected into the combustion chamber in the Prius is very small and even if it were water it would be injected in as a very fine mist that would be compressible, and this will be pushed out on the exhaust stroke.
    I have a petrol lawn mower that I have not used for three years stored outside under a car port. A friend asked if I wanted to sell it and I said he could have it. Took it out onto the lawn checked to see if there was any petrol in it and there was possibly a cup full left in it. Pulled the starting cord three times and away it went. Three years outside and a vented cap.
    usnavystgc likes this.
  2. usnavystgc
    3,159
    990
    Tucson, AZ
    Awesome testimony Brit. Of course there will be the question as to whether it was mixed with ethanol or pure petrol. I have had similiar experiences as well (mostly with cars though).
    I once started a 61 Ford pickup that sat for 5 years (according to the owner). All I did was replace the battery and prime the carb. I ran the old gas until the tank was nearly dry, replaced the fuel filter and drove it for 2 years after that. No flush of the fuel system, no additives, nothing. Now, this would not be my advice to anyone but, I only paid $150 USD for the vehicle and didn't expect it to run at all. Also, there was surely no ethanol in that fuel (this was in 1983).
  3. Britprius
    5,194
    1,922
    You just jogged my memory (needs a lot of jogging these days) about ten years ago I bought an MGC basicaly an MGB with a 3ltr strait six engine from the Austin Healey 3000 that had been rolled and stored in a barn for 12 years. After cleaning of the hay and chicken sh-- fitting two new batteries (6volt) and a new diaphram in the fuel pump turned it over a couple of times and away it went on the fuel in the tank.
  4. usnavystgc
    3,159
    990
    Tucson, AZ
    That's awesome Brit.
    Me being a thinking man, here's what can be done to put all of this to rest.
    What if we put a siphon hose in the tank (all the way to the bottom) and siphon some of the gas out. If there is water in the tank, it will be at the bottom (since water is heavier than gas). Then report what comes out. If its water, drain it until only fuel comes out. My money is betting that only gas will come out.
  5. Britprius
    5,194
    1,922
    I'm with you, what ever happened to drain plugs to expensive I suppose.
  6. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    All these barn find stories you're telling are cute, but apples and oranges, fellas...
    The siphon hose is a good idea, but you'd need to send the gas to a lab for testing. How else are you going to test for water content... by taste?
    ...except that the water may be in solution. Especially if you're stirring it up with a hose.
    If you're going through the trouble of siphoning, why not... empty the tank altogether?
  7. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Better express yourselves without resorting to name calling people or infractions will be handed out to the offenders.
  8. Mopee346
    Mopee346 New Member
    Wash state USA
    Hello all,
    I realize this is a old thread but here goes.
    This summer, July 2024, I purchased a 2004 Gen 2 or 3 for $600. It has 83,000 miles on the odometer, original ownner said they bought it new, I believe him judging from the inside, and all the orginal equipment still in the car. Story goes he bought it for his daughter, who has since moved away, and car was taking up space in their garage. So they had a wrecking yard come pull the car onto a truck and haul it to yard. When I saw it, the 80 year old owner was removing the license plates, old license tabs, 2021. Yard gave him $300 for it. Enougf history.
    I towed it home, about a mile without raiseing front wheels, with a newish 12 volt in it the brakes worked. But it wouldn't start even with new yellow top 12 volt battery. Tried to add fuel, would not take any, it appeared to be full.
    I put a Dr. Prius OBD2 Adapter (Carista) on it, and was told hygrid battery cells 3,4,6 were dead.
    Now after all that here is main questions; I will replace the hybrid however I wonder if I need to do more besides checking all fuids? Will just a new hybrid start the car? Do I need to drain the fuel? Judging from this thread I am thinking purhaps not.
    What say you all.
    Thanks
    Mopee346
  9. bisco
    52,807
    you need to get a prius aware scanner and read all the codes and sub codes. then post them in a new thread.
    all the best!
  10. Mopee346
    Mopee346 New Member
    Wash state USA
    Thanks
