Static Discharge
Discussion in 'Gen 2 Prius Main Forum' started by aiaman, Mar 15, 2009.
  1. fuzzy1
    10,720
    On my old Ford Zapper, when remembered, I would grab a metal portion of the door before stepping out of the seat to try to bleed the charge as it was created . Even then, I'd still feel shocks as the clothing and seat fabrics separated, but they were weaker than waiting for it to hit all at once.
  2. ceric
    ceric New Member
    1,114
    Fremont, CA
    One of the reasons why I got leather seats.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    I have a big pump spray bottle of anti-static compound which is used to reduce static build up in electronic assembly areas. I have often thought about spraying my car seat with it, but I'm not sure what sort of long term damage might occur.
    Tom
  4. dogfriend
    7,512
    1,191
    Carmichael, CA
  5. qbee42
    18,058
    3,082
    Northern Michigan
  6. dogfriend
    7,512
    1,191
    Carmichael, CA
    Just run an extension cord back to the HV battery.
  7. qbee42
    18,058
    3,082
    Northern Michigan
    Knob and tube work okay?
    Tom
  8. dogfriend
    7,512
    1,191
    Carmichael, CA
    I think so. Just make sure the glass insulators are rated for mobile applications.
  9. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Out here in AZ where the humidity is notroiously low, static electric discharges on just about anything is very common. I've been zapped on just about every car I've owned - including my Prius. My wife got hit with a spark that was heard 10-feet away right on the business end of her right boob. As much as it hurt her first instinct was to put her hand over the impact zone and rub it but obviously couldn't. We were in public and one of my friends was standing right next to me when it happened. I must say he blushed one of the darkest colors of red I've ever seen.
    Yes, my wife is okay and doesn't run around speaking in tounges, barking at the moon, or chases hubcaps.
  10. dogfriend
    7,512
    1,191
    Carmichael, CA
    I have some relatives that live in Nevada and I recall them complaining about how humid it is in Sacramento. (Its not, but I suppose its all relative)
    Up until last Oct. I worked in a facility where we manufactured electronics. Some of the devices we used could be damaged by a discharge < 100V. That is below the level where a person would feel the spark. We wore ESD smocks (lab coats with carbon fibers running thru the material) and ESD shoes. We had static dissipative workstations and static dissipative flooring that was all connected to ground (earth) in the electrical system. We also ran ionizers at critical workstations to neutralize any charge buildup on non-conductive materials.
  11. qbee42
    18,058
    3,082
    Northern Michigan
    You should have kissed it and made it better. :D
    Tom
  12. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
    :doh:
    I need a drink ...
  13. jayman
    13,439
    641
    Winnipeg Manitoba
    It's my understanding folks *pay* top dollar to have this done. You should remind her how lucky she is to be married to you, as it didn't cost her anything at all ...
    I'd settle for a gal that did Option 1 and Option 2. Option 3, meh, I could take it or leave it ...
  14. jayman
    13,439
    641
    Winnipeg Manitoba
    :evil:
    I'm so glad you brought that up ....
  15. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    Ironicly, that is what she said...
  16. qbee42
    18,058
    3,082
    Northern Michigan
    And you didn't?!?
    :doh:
    Tom
  17. jayman
    13,439
    641
    Winnipeg Manitoba
    And .... ? Us men usually have to get pretty creative to get an invite like that
  18. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    I never get that with my leather seats.. but when I lived in Washington and my wife would get out of my Jeep "had sheepskin fur covered seats" she would get zapped on a regular basis as she touched the door as she went to close it.
    She used to get so mad at me "like it was my fault"....
    I just told her if her legs weren't so short she wouldn't slide her butt so well over the fur and build up such a nice charge on the way out!...
    That never went over too well.
    I think what made her the maddest is that I never got shocked... "longer legs!"
    Or maybe it was because she got out first!.... shhhh "secret"
    That could certainly be the case if the buildup was from wind against the car body!
  19. EZW1
    EZW1 Active Member
    722
    81
    Phoenix, AZ
    2016 Prius v wagon
    Four Touring
    If we weren't in public, I would've.
    My wife is pretty open about stuff like that and often teases me or dares me - but getting embarrassed in public is a hot button with her. Believe me... I respect that. Too bad I had to miss a good opportunity, though.
  20. qbee42
    18,058
    3,082
    Northern Michigan
    Well that clinches it. You need to zap her in private. May I suggest a Violet Wand. :D
    Tom
