Stealer quoting me $200+ /per injector
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SactoPrius, Mar 9, 2024.
  1. SactoPrius
    SactoPrius New Member
    Sacramento
    Man, that seems awfully high for a single injector. Is this astronomical price right for OEM or are they trying to rip me off? I checked Amazon and they have Chinese knockoffs for $40/ set.
    My 2008 Prius has 105k miles on it, I was going to just swap them out since the car is not idling like it used to. No way do I feel like paying $900 US for a set of four! If I get the Cheepo Chinese I could afford to replace them 20x and still be cheaper than one set of OEM.
  2. Tombukt2
    Tombukt2 Senior Member
    13,857
    2,516
    Durham NC
    Yes so you have to shop around among the Chinese brands and look at reviews and specs and all that kind of thing sure you're taking a chance but it only takes a few minutes to pop them in on a generation too save your old ones you can send them out and have them cleaned and refurbished for $20 an injector or something whatever it is I can't imagine in today's manufacturing climate that this would be any kind of serious accomplishment to make injectors I mean feel injection has been around now for 70 years so there's always that I would try it. I haven't had to pull the plug on this in a generation too yet mind you usually just some good fuel additive and drive on you know drive it down the highway every so often with some techron in it things like that there's a lot of good so I've got a few here with $300,000 and a few with about half that they all idle and run about the same and get about the similar gas mileage depending upon who's driving so they're pretty consistent cars.
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    I doubt I would invest in replacing 105k mile injectors without at least trying top tier gas for a few tanks or quality injector cleaner.
    At worst, refurbished OEM injectors are available from Rock Auto for $30 each.
    Is the $900 quote for new injectors and installation?
    Brian1954 likes this.
  4. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    That's assuming you get them to run right in the first place. We have a few threads around here where people ....didn't.
    I wouldn't buy the $200 ones at the dealer either.
    On the other hand if I really thought my injectors were trouble I would use one of the rebuild services. Some do swaps, some rebuild yours and send them back, depends on how much downtime you can live with.
    Either way you wind up with real Denso injectors rebuilt with real parts and seals, usually for around $35 per.
    Good luck!
  5. ChapmanF
    19,018
    We did some of that here on PriusChat too. I'd send the last restored set to who needed them, they'd send their old set to the restorer, the restorer'd send them to me.
    I still have the last restored set of those. They're the ones used in gen 1 and gen 2. I know gen 3 is different. Don't know about the c.
  6. Mr.Vanvandenburg
    1,361
    660
    2020 Prius Prime
    Did you measure ohms on each? If the ohms are ok, just cleaning should do. I guess you made sure it was injectors that are causing the rough idle. I would almost bet it isn’t at 105k.
  7. SactoPrius
    Sacramento
    Thank you all for your input. Just to give some further background, I have already replaced the sparkplugs and cleaned the MAF (which didn't look too bad).
    The car just doesn't start up and turn off as smoothly as it used too. When turning off it seems to "diesel" for a half second, like maybe one cylinder continues to fire. If that makes any sense. It's not a terminal problem. I don't have any codes. I just feels not right.
    I think for now I am going to pull them and do a thorough cleaning. If they aren't misting right even after the clean then maybe @ChapmanF would be open to swapping.
  8. Mendel Leisk
    42,343
    Did you clean throttle body? If not I’d try that first.
    IIRC cleaning the internals of injectors is tricky, involves powering them and running a solvent through??
  9. SactoPrius
    Sacramento
    The throttle body was in pretty good shape. Barely any residue. I sprayed it with some cleaner and wiped it down internally.
  10. Leadfoot J. McCoalroller
    8,288
    7,801
    Pennsylvania
    2018 Prius c
    The plugs weren't from Amazon, were they?
    We have threads about those too.. one member already had the tip fall off a counterfeit plug and beat the piston face pretty well.
    You have to be really, really careful about getting auto parts from the internet.
  11. TMR-JWAP
    6,404
    6,095
    Columbia, SC
    For the MAF, keep in mind the portion visible when looking down the throat of the throttle body is merely the temperature sensing bulb. The MAF element is enclosed internally inside the plastic housing and requires removing the sensor from the throttle body to be able to spray it or wipe it with a q-tip.
    If this is your main concern, and you have no CEL/DTCs, a weak/aged HV battery often shows these symptoms as an early indicator of weakness, where the transition between engine on/off or off/on isn't very 'crisp'. I've noticed quite often, a new battery or good refurbished battery makes this transition much more crisp.
    dolj likes this.
  12. SactoPrius
    Sacramento
    LOL, no they were stock OEM that I got from the dealer.
    I took it complete off and sprayed it down wit MAF cleaner both the bulbs and wire. Honestly for a car with 100k, it looked pretty good.
    Interesting what you said about the battery. I know it needs some tlc. I haven't addressed it because this is my only transportation besides my motorcycle. Once it stops raining I was planning on replacing some cells and running it through a refurbish/rebalancing cycles using a charger
