"Stealth" at speeds above 42mph
Discussion in 'Gen 2 Prius Main Forum' started by TucsonPrius, Jul 9, 2004.
  1. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    Well that's rather primitive.
    How about if it sends the data as a spreadsheet through a bluetooth connection to your cell-phone or PDA?
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    ok make mine USB as I wouldn't want someone beside me at an intersection with his PDA having a look at my data or sending me a virus. I can imagine a virus that makes the car miss at say 41 44 miles per hour, the dealer would probably never figure something like that out.
  3. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    If you're talking about using the BT connection in package 9 systems, it's not possible.
    It's pretty firmly tied into the telephone portion of the nav package, and as far as getting it to do much other than the butchering of vCards it likes to do, I don't think it'd be very easy to do. You'd have to modify the firmware of the car, and that's not something I'd think many people would do lightly.
    As an alternative, why not just go out and pick up a discontinued palm with the universal connector and use that as your display? It's easy enough to hack the universal connector into a serial connection....
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    For the poster who stated that the valves are held open, this is not possible since the cams still spin during engine freewheeling. What is possible though is that the intake cam timing can be modified via VVT-i to minimize pumping losses during this "free spin" mode. This minimizes drag at speeds above 42mph if no engine power is requested - unless you're coasting where this could be desirable if regeneration drag alone is insufficent.
  5. Frank Hudon
    4,147
    an internal combustion engine only requires about 2 1/2 hp to start it so very little energy from the CVT is needed to spin the ICE and no the valves are never held open as Rick pointed out. The VVTi retards the intake cam to lower pumping pressure.
  6. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    well there is a principle of momentum and its the same principle that says to maintain a speed of 65 mph, an average car expends about 23 HP to do so. Because of the lower than average wind drag coefficient, that figure would be lower for the Prius. so you see, from a running start, not much is needed to maintain speed. that is the beauty of the atkinson cycle engine.
  7. victor
    victor New Member
    414
    Gilching Bavaria Germany, & Drapanos, Crete, G
    Fair enough. As I said I am no expert but I got this impression from this
    from Johns site http://john1701a.com/prius/prius-misconceptions.htm about 1/2 way down the page. (Bold is mine)
  8. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    I didn't think all the Valves were all held open all the way through each cycle. I thought the Timings were adjusted so that the Intake and Exhaust Valve openings Overlapped - IE, there is always at least one valve open.
    This means SOME pumping loss, but far less than if both valves were closed at the same time at a point in the cycle.
  9. ceemom
    ceemom New Member
    Neutral to Drive
    Just wondering about coasting. Can you shift from Neutral to Drive while coasting at 55mph?
  10. jamarimutt
    jamarimutt New Member
    985
    Re: Neutral to Drive
    You can do this at any speed, back and forth, and nothing noticeable happens, other than the car gaining or losing speed.
    You can also shift from D to R or even hit P at any speed and you won't damage the car; as a protective measure it will shift, you guessed it, into neutral.
