Steam clean engine?
Discussion in 'Gen 3 Prius Main Forum' started by mengoni, Jun 27, 2019.
  1. mengoni
    mengoni Junior Member
    33
    Kansas
    When I bought my 2010 three years ago the engine was very clean. Now not so much.
    Can I use my steam cleaner on my engine to get the dust and grime off? Or should I just leave it alone
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
  3. Mendel Leisk
    38,704
    I'd use vacuum, compressed air brushes, IF it bugs you. I'd avoid spraying water in there.
    Are you driving on dirt roads?
    Is the engine underpanel intact and complete? It helps some.
    Something else you can do, is push some foam tubing (the type they use for insulating hot water plumbing pipes) onto the crimped edges down the sides of the engine bay: seals it a bit better.
    #3 Mendel Leisk, Jun 27, 2019
    RMB likes this.
  4. ken2116
    ken2116 Junior Member
    37
    16
    Northern CA
    2019 Prius
  5. Sal43
    Sal43 Member
    119
    75
    Pennsylvania
    Steam cleaning may damage important sensors in the engine compartment, so I wouldn't risk it.
