Steep hill + 0 EV range + Cold ICE = overloaded charger?
Discussion in 'Prime Fuel Economy & EV Range' started by arthur92710, Sep 21, 2017.
  1. arthur92710
    arthur92710 Junior Member
    25
    NY
    tldr: On my way back home from work I run out of EV range right before the top of a very steep hill. My prime switches from EV mode to HV mode, the ICE kicks in and a few seconds later I start to decend the hill.
    This is a very steep hill and it take have to apply pretty much 100% of regen braking not to go over 50mph.
    I've noticed on the Hybrid system display that power only flows from the motors to the battery. There are no arrows going from the engine to the battery. Same on the Energy Monitor on the 11in screen. But the engine is running the warm up cycle so there should be power flowing out.
    Is this a bug in the displays or is the charger already at 100% because of the regen?
    If it's not a bug, should I run the warm up cycle sooner so I'm not losing that energy?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    That's totally normal. I've since three hybrid system operate that easy with all 5 generations.
    It simply just consumed all the electricity being generated.
  3. arthur92710
    25
    NY
    Are you sure it is? So then it's a bug in the displays?
    Any idea on how I could verify that the energy from the ICE and the regen is both simultaneously being sent to the battery?
    I'm thinking measure the current flow during 100% regen, measure the current flow during stationary ICE warm up, add together and compare to the total current flowing into the battery during my situation in the first post.
    Does the same OBDII (generic ebay bluetooth type) scanner that worked with my GEN 3 work in the Prime? I haven't tried yet.
  4. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    During engine warm-up it is better to leave the engine unloaded than attempt to extract power from it as a generator. To do so will result in additional fuel consumption at a time when it is operating inefficiently - there isn't unused power available.
    kevin
  5. Rmay635703
    Rmay635703 Senior Member
    2,703
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Try to crest the hill at as slow of a speed as possible (like 15mph)
    Then allow the hill to accelerate you
    priuscatprimeguy likes this.
  6. arthur92710
    25
    NY
    I'm pretty sure that my gen 3 will send power to the battery when it's warming up. Probably not much but also not an insignificant amount. I would guess that a prime does the same.
    I do when there's no one behind me.
  7. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    There is no energy from the ICE - it's just idling to warm itself. It's either completely unloaded or mostly unloaded.
  8. bisco
    52,858
    this strategy will extend the prime engine life beyond that of the hybrid.
  9. arthur92710
    25
    NY
    Problem solved, kind of. I drove over 400 miles for various trips in the Prime this weekend, got home Sunday night with like an 1/8th tank of gas left.
    This morning I took my regular route to work and back and I got through my whole 34 mile hilly commute on just EV range. I got home with 1.4 miles to spare.
    The weight reduction helped out a lot.
    When I got to the top of the hill in OP I had 1.4 miles of range left, it's mostly down hill from there so I got home for free.
    Ill post some pics in a few. Unfortunately I didn't reset my trip counter, I'll to it tomorow.
  10. arthur92710
    25
    NY
    6.2 miles/kwh!
