Steering Angle Sensor
Discussion in 'Gen 3 Prius Technical Discussion' started by tnt4him, Mar 1, 2024.
  1. tnt4him
    tnt4him Junior Member
    53
    Beaverton Oregon
    I have a 2015 Prius trim 2, 127K. I bought this car with the anti skid light on constant. First scan said no faults. So, I found on YouTube a calibration method of jumping pins 4 & 13 on the OBDII. Anti skid did not go off. Second scan, I now have c1231. So, I connected my Maxicom MK808 and went to live data. There I could see the steering angle sensor stuck at 850.5 degrees. No response in turning the wheel. My question is if it doesnt move is it the clock spring thats bad or is it the angle sensor not responding that is bad? I'll probably buy both together assembled if no one knows the answer. But if it is one of the two parts, the clock spring or the sensor is there a correct meithod of assembling the two? Its says on the sensor do not remove from clock spring. I imagine the spring becomes unwound and then needs to be correctly wound back up. Can't seem to find that info, although I see on youtube people spinning the sensor back and forth and then aligning at 12 oclock. No explaination of what exactly they are doing. Hoping someone here has run the gammit and knows.
  2. ChapmanF
    18,851
    The impression I get from the manual is that if C1231 is your only code, the sensor is likely the culprit (unless you can get the INF code and it's 703, in which case you might check the voltage arriving at its +B terminal. (Anyway, their troubleshooting steps have you check both the +B and the IG voltages, among other things, in any case before condemning the sensor.)
    I don't think Toyota sells the sensor and spiral cable separately. It may be possible to separate and reattach them aftermarket, but Toyota doesn't seem to trust us to do it right.
  3. tnt4him
    53
    Beaverton Oregon
  4. tnt4him
    53
    Beaverton Oregon
    Thanks, I agree it's more likely the sensor only. But in searching aftermarket sensors only on Ebay, part #89245-74010 for my 2015 Prius seems to span only 2010-14. I can find that same number for 2015 but its complete with the clock spring and with the same sensor #89245-74010 attached to it. Strange. As funny as you mentioned that Toyota doesn't trust us DIY'er it seems for 2015 you have to buy the whole assembly but if you have a 2014 you can buy them separately (?) So, I could buy the sensor only and attached it to the clock spring against Toyota apparent restrictions on how they sell these things. It's just kinda strange. Dealership gave me part number 84307-47020 for the whole assembly. Only $649! Compared to $50 sensor only on Ebay.
  5. Tombukt2
    Tombukt2 Senior Member
    13,725
    2,483
    Durham NC
    So this is on the clock spring oh just take that off of a 20 whatever latest model you can that will fit you in the Gen 3 series I don't know what that would be but God there's about five or six of them sitting around where I go all with the steering wheel still on them couple of them pretty low mileage.
  6. tnt4him
    53
    Beaverton Oregon
  7. tnt4him
    53
    Beaverton Oregon
    Yeah, I decided to buy one from someone parting out a Prius. Its OEM and not China aftermarket. Clock spring and sensor together, not guessing, hopefully only have to do it once.
  8. tnt4him
    53
    Beaverton Oregon
    So I bought a used OEM steering angle sensor and it did not solve the problem. In diagnostics on my Maxicom Mk808 testing ABS/ECB sensors it found the C1231 again (still stuck at 850.5) but also noted that all wheel sensors had low or abnormal readings. But, code c1281 said the master cylinder had a low sensor output. Not sure exactly what this means. None of these codes show up in a scan. I found them by testing. There is the master cylinder atttached to a black electronic box, the anti skid control unit witha a pin connector connected to it. Manual says to check wires, pin and secure. I'll check that. Called toyota they said that the master brake booster is on voluntary recall. Meaning the dealership policy decides if they will replace this. Must be under 150k/ 10yrs. However, my car is a salvage titile and that may void the voluntary recall.
    Has anyone gone down this path before? Am I on the right track looking at the master brake and anti skid control unit?
    PS: dome lights work fine
    #8 tnt4him, Mar 9, 2024
  9. Tombukt2
    13,725
    2,483
    Durham NC
    Generally when you get to this point you need to delve in to an online manual usually behind the paywall The tests for this issue are extensive and long have to write down stuff to remember it but yes you're barking up the right tree I would imagine generally should be replaced as a pair unless you're just feeling really lucky or very skillful in your diagnostic and I mean very skillful when the manufacturer recommends replacing both parts at the same time You know there is a very decent reason for that.
  10. tnt4him
    53
    Beaverton Oregon
    Thanks, the online manual behind the paywall? Not sure what that is. any online manual?
  11. ChapmanF
    18,851
    This wiki page is all about the manuals.
    Toyota Service Information and Where To Find It | PriusChat
    If you go directly to Toyota's online site, there is a (small) fee for two days of viewing—what's sometimes called a 'paywall'. It's a lot less than a dealer visit and a lot less than what old sets of factory manuals on dead trees used to cost.
    The same wiki page also tells you all about various alternatives to going directly to Toyota's site.
  12. tnt4him
    53
    Beaverton Oregon
    I continued my diagnosis and in doing so managed to get more trouble codes. I believe its because I cleared memory for G and Yaw sensors. This produces the abs and brake light. I have been able to get out of this by doing a linear valve offset and those codes disappear once the procedure is complete. But, this time after doing the required memory reset for the abs the linear valve offset wont work and i have four codes insead of one. I'm thinking my skid control ecu is messed up and not responding. It has low abnormal output to all abs wheel sensors and the traction light is constant and the steering angle sensor is stuck at 850.5 I have a shop manual on the way so I can check voltages but i suspect its the skid control ecu.
  13. George Jung
    George Jung Junior Member
    Las Vegas Nevada
    Did you ever get this fixed? My steering angle is also stuck at 850 and I am unable to even begin the Brake Bleed Procedure. None of the calibration functions work.
