Steering Bolt Recall
Discussion in 'Gen 2 Prius Main Forum' started by bogeybob513, Jan 8, 2013.
  1. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    How do I tell if my dealer actually did the work? I could see the car from a viewing window of the work area, and never saw it go up. They claim they inspected the shaft and just replaced the bolt. They had the car for 2 1/2 hours, but every time I looked it was on the ground.
  2. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Paraphrasing Bret Maverick: If you can't trust your Toyota dealer (banker in the 1960's TV program), Who can you trust?
    JeffD
    ps: If you have an accident traceable to a steering issue you would have a solid lawsuit.
    xs650 likes this.
  3. PriusCamper
    PriusCamper Senior Member
    11,095
    4,515
    Pacific Northwest, USA
    When I drive down the highway lately my steering wheel is turned 6 degrees to the left even though the car is tracking straight down the road... Tire wear seems fine, alignment seems ok... Is this problem likely related to the recall? Or is it something else?
  4. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    I share your skepticism. Take a look at the bolt and see if it looks clean and new. Parts on a 2006 shouldn't look shiny new unless they have been replaced. I doubt they would bother wiping the old bolt off if they didn't replace it, but they might have.
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  6. bogeybob513
    bogeybob513 rtc513
    147
    Myrtle Beach, SC
    They have already screwed up, including not properly fastening the connection to the inverter cooling pump, resulting in me getting stranded, plus not putting on the oil cap after an oil change! Caught that or oil would have been all over the engine compartment.
    Just where do I look to be able to confirm the "fix"?
  7. bisco
    49,455
    i would try another dealer next time. not sure how you can confirm the repair. i suppose if they were inclined to lie, they would have said they replaced everything.
  8. windstrings
    windstrings Certified Prius Breeder
    6,280
    378
    Central Texas
    When they replace the shaft. They drive it to see of they got the alignment right.
    Either your guy didn't bother checking himself or he did it wrong.
    Alan.. Sent with Tapatalk 2
  9. windstrings
    6,280
    378
    Central Texas
    There are 2 scenarios.
    1. Where the bolt goes into the shaft if it's recessed the whole shaft needs replaced.
    2. If it's not recessed, all they need to replace is the bolt. The shaft is good composite and not under recall.
  10. PriusCamper
    11,095
    4,515
    I haven't got the recall done yet, this is something that I just noticed recently... Is this problem related to the recall or is it likely something else?
  11. windstrings
    6,280
    378
    Central Texas
    The recall has to do with the shaft composite being weak "if you have the wrong lot" and is vulnerable to breaking under extreme stress.
    If your needs replacing they should fix your steering at the same time, if only your bolt needs replaced they can probably adjust it for you with little or no charge.
    It's just a matter of slipping it out of the yoke, turning it a bit and putting it back in.
    Hopefully yours needs replaced.
    Makes me wonder if the gear slipped?
    PriusCamper likes this.
  12. PriusCamper
    11,095
    4,515
    So weird, I had a very similar problem with my last car, a 92 Subaru... I guess my steering wheel karma turns to left for some reason?
  13. windstrings
    6,280
    378
    Central Texas
    Your tie rods get adjusted when you get out of align "or if you hit something", at any rate, when the guy does the alignment he must make sure the steering wheel is straight and then make equal adjustments to each tie Rod.
    If he brings the tire into alignment by only adjusting one, it will turn the steering wheel.
  14. dsam1961
    dsam1961 Junior Member
    A week ago my daughter who 'inherited' the Prius called me and said there was a problem with the steering.
    Started a video call and the steering is completely gone with no connection to the front wheels at all.
    She had just pulled off the freeway into a gas station and as she pulled onto the pub the car went straight but it was at very slow speed this was the least bad outcome in this scenario.
    Toyota claim the recall work was completed in 2016 or 2013 (two different stories from two different 'brand engagement specialists')
    If this work was actually performed and the incident happened again - should they redo the work or is this now 'wear and tear' at 10 or 7 years since the work was done.
    I have been driving for 50 years and never had steering 'wear and tear' issue.
    Any ideas - as I am not sure I should spent close to $2000 to fix this issue on such an old car
  15. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I had a steering wheel repair originally done at my expense twice, but when the second steering recall (there were two separate recalls) occurred, I discussed it with customer service several times and after submitting a bunch of paperwork, they refunded much of my expenses. It may be worthwhile to raise this issue with customer service, especially since it was a dangerous failure.
    JeffD
  16. PriusCamper
    11,095
    4,515
    The symptoms for this problem before it gets bad is uneven tire wear and that you can grab a front wheel and shake it left to right and it's a tiny bit loose. Your symptoms sound like full blown failure and might not be related to this recall... I've always noticed how employees at the wrecking yard are quick to pull off Gen2 steering racks for resale, so you aren't the only Prius that didn't get the recall done before it expired and it was as easy as adding some bolts. If I were you I'd find a local mechanic with more reasonable rates than a Toyota Stealership to see if there's a repair they can do without replacing the rack and buying a used rather than new rack if it has to be replaced.
    #16 PriusCamper, Mar 5, 2023
