Steering not Returning Issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by thechadster, Jan 22, 2018.
  1. thechadster
    thechadster Junior Member
    2010 Prius doesn't return to center after turning right. It is drastic so I believe it isn't an alignment issue. I have return it to center myself.
    Also, which is probably connected to the steering issue, while driving the car if I gently move the steering wheel to the right I hear a humming/vibration in the left wheel. Basically as the car shifts its weight based on steering input there is a humming noise. No snapping/cracking noises when going over bumps either.
    Now I know what you might be thinking.... Wheel bearing......
    I replaced the wheel bearing and that didn't make a difference. I also have new tires and a recent alignment.
    Any ideas?? I'd like to have some knowledge before I take it to a shop....
    Thanks!
    49,378
    cvj? how many miles on her?
  3. 4est
    4est Active Member
    207
    121
    Romania
    2013 Prius Plug-in
    Excel
    Steering rack.
    Why do I always see the "how many miles q"? What does that has to do with it?
  4. Dxta
    Dxta Senior Member
    1,932
    766
    Lagos
    I'm gleaning towards your electric steering rack. Especially, the power steering electric motor.
    Asides that, have you taken a look at the tierods, to see if they're stuck?
  5. bisco
    49,378
    the older and more miles, the more suspects that may be likely.
  6. MikeDee
    MikeDee Senior Member
    1,550
    590
    San Francisco Bay Area
