Steering paddle for EV mode only.
Discussion in 'Gen 4 Prius Main Forum' started by JayLn, May 7, 2017.
Tags:
  1. kevinwhite
    kevinwhite Active Member
    333
    200
    Los Gatos Ca
    You're right - I was mixing up my generations.
    thanks
    kevin
    alanclarkeau, RCO and Prodigyplace like this.
  2. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Better than mixing your drinks, I suppose. Hic! :sick:
  3. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    It's just my idea, because I think it is better to have paddle to maintain speed when you reach the speed you want, and I never said paddle to turn off ICE I don't even know what ICE means, it just always makes me think why I need to check if the gas engine is On already (EV=letter is gone on the panel)on the panel when they can just place a paddle on the steering so we can just press it to maintain speed in EV like 40mph and just press a paddle. And here in Bay Area SF, we have a lot off hills here to keep the battery perfectly Full and when I say Full it's Full Bars, the only time I hear engine charging the battery is when I am stop for a while watching Warriors or Giants game with my air-condition On. And I bought a Prius to make sure I can use all the battery charge of the battery, I think that is why they place the battery there so we can use it and save gas. That is why it has better mpg in city compare to highway, unless we drive 65mpg on freeway.
  4. Prodigyplace
    12,710
    11,848
    Central Virginia
    ICE = Internal Combustion Engine - the gasoline engine,
    The Prius is designed to run mainly as a Hybrid car, not as an EV (Electric Vehicle). IT appears yo want to run it as an EV but Toyota has designed the car and its software to be most efficient as a Hybrid. Forcing it to run as an EV like you want can possibly shorten the life of the Traction Battery too.
    The Prius Prime is a PHEV (Plugin Hybrid Electric Vehicle) that is designed to run in purely EV mode and can be charged from a wall outlet. For longer trips, it also functions as an EV. It has a larger Traction Battery and different software and eCVT transmission.
    kithmo and RCO like this.
  5. JayLn
    JayLn Active Member
    248
    141
    Four Touring
    I don't want it to run on EV alone, you are missing my point, everyone knows the best way to get good mpg is maintain speed by using Electric motor maintaining speed it doesn't defleet the battery using this style of driving a Prius even when I am on Fremont no uphill or downhill like SF has I can not make the ICE have to charge the battery because braking charge it and I accelerate using gas engine fast and use E motor to maintain speed, I learned that from here, and I think that is why the battery is there to use the charge of the battery not to just maintain it at full charge all the time, and I already said I am here in SF with all the hills even I am using this style of driving a Prius without this paddle mode I can't force the ICE to charge the battery because one downhill here will charge the 3 bars battery to Full Bars. And I have a 2015 prius which I traded in, and use the same style drove 67,000+ miles on it for 2yrs and 1 month they check the battery it is still has 98% capacity so damaging the battery is not an issue here these battery that they put on are Prius is top of the line with regards to quality.
  6. bisco
    52,803
    i don't think the prime has steering paddles, but it would be a good idea.
  7. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Is it bed time yet? :sleep:
    pilotgrrl and kithmo like this.
  8. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Riverboats have paddles. :whistle:
    There is actually paddle on the Prius steering wheel to maintain speed it's called Cruise Control.
    pilotgrrl, RCO and alanclarkeau like this.
  9. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    This is where you are mistaken. It is not more efficient to maintain speed using the electric motors. Any time you use the battery to do anything, at some point in time the engine will have to kick on to recharge it and you will lose efficiency because a gasoline motor generating electricity and storing it in a battery has losses.
    There are very specific instances where it may increase efficiency, and that is when it requires less power than the engine provides in it's most efficient RPM to maintain speed. If that is the case, then you will find your car is already in EV mode just pressing the pedal normally to maintain your speed. If pressing the pedal to maintain your speed causes the engine to kick on, then it means that you are already traveling at a speed or under conditions where it is more efficient to just let the engine drive the wheels, or that the engine is producing more power than you need to maintain speed, but it needs to recharge the battery and so the excess power of the engine is used to charge the battery.
    There absolutely is no "overall battery life percentage" reading that anybody can obtain from a Prius. Your dealership never checked your battery and lied to you.
    pilotgrrl and RCO like this.
  10. bisco
    52,803
    maybe the o/p meant neutral paddles.
    kithmo likes this.
  11. Chippingawayatlife
    Chippingawayatlife Active Member
    159
    116
    San jose
    Id day this is closed. I mentioned neutral paddles in this post before too. He clearly wanted it for constantly going up and downhill in the city. But the hills allow him to full recharge that small battery quickly, thus reducing the efficiency differnce you are mentioning. I think op understands the efficiency concept of recharging with the ICE.
  12. bisco
    52,803
    yeah, i thought it was closed until it wasn't.:cool:
    RCO likes this.
