Steering Power Low
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by jZerbe0011, Jul 5, 2018.
  1. jZerbe0011
    jZerbe0011 Junior Member
    Lancaster, PA
    Just got a message on the PIP of my 2017 Prime with 47k Miles that said:
    Hybrid System Stopped
    Steering Power Low
    I was stopped in a parking garage with the ignition ON but the car in PARK and I was out of the vehicle for about 5 minutes got back in and I got this message and the READY light was out.
    Any ideas are appreciated!
    49,399
    did she fire right up again? could you have been in acc mode by mistake?
  3. FuelMiser
    FuelMiser Senior Member
    1,294
    884
    Monument, CO
    If the Ready light was out, you were using the small 12 volt aux battery to power everything. It probably went low while the Hybrid system was stopped. "Steering power low" is related due to the fact that Prius power steering is electric, and with a low aux battery, the car is reporting there was not enough power to steer. Hopefully, you were able to put the car in Ready, and got full power back...
  4. jZerbe0011
    Lancaster, PA
    It was READY, but in Park when I left the car when I got back in the message popped up and the READY was off. I checked in on it after 5 hours of charging and it fired right up. Still would like to know exactly why I got the message though. There are specific messages for “low 12v battery” and “low traction battery” very curious why the steering was the system that was affected this time. Unless when I got back into the vehicle I bumped the steering wheel that that’s what prompted the message.
  5. bisco
    49,399
    there may be a troublecode logged with specific service manual troubleshooting tree. could be a defective steering system ecu.
  6. jhonatan gobay
    jhonatan gobay New Member
    Israel
    Did you find the answer?
  7. bisco
    49,399
  8. OMER1994
    OMER1994 New Member
    Jerusalem
    I have this msg to in my car ,did u find answer for that ?
  9. Mukunda
    Mukunda Junior Member
    67
    I got this one along with Engine overheat.
    Engine starts and makes some noise and stops, then this sign pops up.
    seeing these codes
    P00B111, P011511, P148F00 AND P319000
  10. bisco
    49,399
    don't leave it in neutral
